Cylinder 5 misfire!!!! 05 g35x AWD
Old Feb 27, 2025 | 12:46 PM
aliycat's Avatar
G35x 3.5L V6
Hey guys, I’m having trouble with my 2005 g35x AWD. I had done a valve cover job and after doing it my car started idling rough and jumping rpm’s lower to idle. I had a cylinder misfire pop up on my scanner so I had changed the spark plugs too. After changing the spark plugs I had the code popped up again for a cylinder 5 misfire so I switched ignition coils 3 and 5 and then it started popping up random/multiple misfires. THENNNNNN i went and bought new ignition coils and replaced it and a replacement spark plug for the cylinder 5 since it was still throwing the code. I thought i fixed it and cylinder misfire 5 still popped up. Just to note I had no check engine lights or any problems with rpm’s before doing my valve cover job. I’m not exactly sure what it could be but I’ve done everything please someone help me. I’ve exhausted all resources and have been working on this car for 4 days.
Old Mar 1, 2025 | 10:06 AM
Mr.GEE's Avatar
20 Year Member
Check for broken wire or damaged connector pins.
Old Apr 29, 2025 | 08:59 AM
Jeffreybonilla5's Avatar
Wonder if u touched the throttle body and didnt do a relearn or even the air fuel sensors
Old Mar 22, 2026 | 08:37 AM
mjtct's Avatar
G35x
P0305
So far I followed the same path you describe and still have the cyl 5 misfire. Assuming now it is a bad injector. What did you end up finding/fixing
Thanks Mike
Rainy
May 5, 2021 11:06 PM
TiIngot
Aug 12, 2019 07:41 PM
Sarah Kibler
Jul 10, 2018 10:31 AM
clarker23
May 20, 2016 10:10 AM
Gossmerjr2
Oct 26, 2012 04:03 AM
