My AT Coupe doesn't want to turn on sometimes.
Old May 21, 2003 | 09:25 AM
Ggirl's Avatar
Does this happen to you guys? Sometimes it takes like 4 tries to get it going. Only happens in the middle of the day when it's hot. Do you think it's the heat?
G35C Desert Platinum/Willow Leather 5AT Aero Pack Premium Pack
Old May 21, 2003 | 09:27 AM
Cali_Eddie's Avatar
Re: My AT Coupe doesn't want to turn on sometimes.
Don't think I've had that problem with my coupe. Where about are you from? Egypt? j/k Well the most it get's around here is about 80 to 85. I'm in So. Cali right on the beautiful coast and never had a problem with mine... Try parking it in the shade or a garage if it get's to hot in the area.
Old May 21, 2003 | 10:31 AM
surewin's Avatar
I only had it happen to me once. I live in cali as well. This was about 6pm. And at time, only had about 500-600 miles on it.
Old May 21, 2003 | 12:08 PM
Msedanman's Avatar
O.F. Administrator
Could be vapour lock in the fuel system where air bubbles into the fuel line on a hot day.
I've noticed this on mine after parking, where underhood gets heat soaked and within about 1/2 hour it's difficult to start. Anything before that it's ok and anything after that it's ok.
<font color=green>GSM</font color=green>
Old May 21, 2003 | 01:40 PM
wickedG35's Avatar
TAKE IT TO THE DEALER!
And tell them what's happening and let them check / do whatever they need to do to make sure it doesn't happen again.
-Blk/Blk G35c
Old May 22, 2003 | 08:13 PM
GforceI's Avatar
G SQUAD
Only problem with taking it to the dealer is the fact that her car only doesn't start sometimes. Oh man intermitent problems are a b*tch to get fixed. With the S2000 the thing would hesitate during acceleration and sometimes stall when stopped, ONCE IN A WHILE. Took about 5-6 trips to the dealer and they could never recreate the problem. Got luck one day and she stalled in front of the mechanic, turns out the spark plugs were bad.
I hope the heat doesn't have anything to do with it cause if it is a problem that involves heat I doubt my Black beauty will like that.
Keep Us Posted.
Old May 22, 2003 | 09:41 PM
G35TR's Avatar
I agree with Wicked. TAKE IT TO THE DEALER!!! Make them fix it. New car should not have that problem. I live in Florida, and have not had that problem. If I do, the dealer will definately be taking care of it. You don't spend $35K on a car to have probs. starting it!!!
Old May 22, 2003 | 10:09 PM
Tabz's Avatar
i got a 6mt and sometimes (havent paid attention to when exactly) it takes an extra few cranks to start the car, kinda like the battery is dead. i'm in toronto and it cant be the heat cause we havent got any yet.
any ideas?
03 G35 coupe SS (GD) 6spd everything but navi
02 QX4 pearl white
00 528 Silver on black
Old May 23, 2003 | 12:08 PM
MaXXXiMaNiaC's Avatar
My brother is actually having the same issue with his G35C 6MT, although he recently had a Audiovox remote starter installed and we were contemplating if that is what was causing the problem. We're in So cali and It was about 100 degrees out 2 days ago when this occured.
We cranked and cranked and it just wouldn't turn over..
After about 2 hours he hit the remote started and it started..
Turned it off and it wouldn't start again..
I dont know if the heat has anything to do with is becuase he was washing his car the night before and it did tha same thing but turned over the second crank..
Maybe something to do with moisture as said above..
Old May 23, 2003 | 12:58 PM
surewin's Avatar
When I got the G, the sales showed me instructions on the chip. She even gave me instructions. Have them somewhere in my glove box. Something like, turn the key to on.....then wait 10 seconds, turn off. turn to on again for 10 seconds, then off. to to on again for 10 seconds then off. After, to try and start the car. It suppose to reidentify the key.
Old May 23, 2003 | 01:34 PM
RamboRami's Avatar
G35driver.com Moderator
thanks for the info Zaid, you're a big help as always [img]/w3timages/icons/smile.gif[/img]
-Ford G35 hahahaaha
Old May 24, 2003 | 01:17 PM
DallyCurtis's Avatar
good thing it wasnt a pinto G35 ...we'd all be blow'd up real good....
hhuuuhhh huuhhh huuh huh
[img]/w3timages/icons/tongue.gif[/img]
Old May 24, 2003 | 03:51 PM
Growler's Avatar
Hey folks.............just a thought. My Maxima (pre 6mt coupe) would get that funny hard start problem at a critical temperature point when trying to restart after the vehicle has been run awhile and sitting for an hour or so off. Nissan has a tech bulletin on this problem (I do not have the reference number) but it was a Hard Start symptom....crank and crank but no start. ( the starter cranked fast. No weak battery stuff)It did not happen frequently, but often enough for me to learn to press the accelerator just enough to overcome and start. Of course the maxima had a hard wired throttle were our G's are electronic wire????
The bottom line for the tech bulletin was that the water temperature sensor was acting up and providing the wrong data to the computer. Since the max's 30DE engine if basically the same as our 35 DE........this could be the issue. I live in So Cal and have not had this problem with my coupe....as a matter of fact I think our G' engines literally explode into start mode instantly. Hope this helps.
Growler
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
ddietz97
Jul 26, 2015 06:16 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
