Coupe seat, is the seatbelt buckle built into the seat?
Old Apr 8, 2005 | 06:08 PM
BlackM6C's Avatar
Hey guys,
Is the buckle built into the seat or just the bracket or what?
Old Apr 8, 2005 | 06:16 PM
BlackM6C's Avatar
****, sorry about that!
Old Apr 8, 2005 | 07:55 PM
Sickone's Avatar
well I just tore out my whole interior (seats, panels, about to pull console and carpet) - I will look. I think it is bolted to it...
Yep - it is bolted to the side
you would have to remove the seat (sort of a PITA)
1) slide seat forward remove the two plastic covers on the rails - use a 14mm to remove the two bolts
2) slide seat back, remove the two plasic covers on the rail
3) !!!! DICONNECT BOTH BATTERY TERMINALS !!!! NOW !!! to insure the airbag won't deploy
4) wait at least 3 minutes
5) remove the 2 bolts
6) tilt seat back and free the wire harness, unplug the various connectors
7) lift out the seat (easier if you have removed the headrest
there ya go
Old Apr 8, 2005 | 08:14 PM
BlackM6C's Avatar
so, will it be an issue using the buckles with aftermarket seats?
Old Apr 8, 2005 | 08:50 PM
Sickone's Avatar
no way I could know, you'd have to bolt them to something
Old Apr 8, 2005 | 11:47 PM
BlackM6C's Avatar
nuts.. Thanks man.. Would it be best just to use a 4 point harness instead? or Are the illegal for street use?
Old Apr 9, 2005 | 12:01 PM
BlackM6C's Avatar
sickone?
Old Apr 10, 2005 | 03:44 AM
civic4982's Avatar
I thought that seatbelts were bolted down to a bolt that goes directly into the chassis as a rule of thumb?
Old Apr 10, 2005 | 03:52 AM
Sickone's Avatar
Hey ya
- I have no iddea what is legal and not for seat belts, 4 point vs stock, etc.
I have seen a couple G's with 4 point at the dyno day a few weeks ago... maybe one of them knows and will see this and post.
Civic4982. Maybe true as a 'rule of thumb' but it isn't true here. The reel, and anchor for the belt are bolted to the body at the door pillar, but the 3rd point (the snap in) is bolted to the seat. It would make sense, given that the seat moves forward and back quite a lot, if it were hard mounted it would be hidden when the seat was forward, and 'loose' when the seat was back as the bucjle would be too far forward,
Old Apr 10, 2005 | 04:29 AM
civic4982's Avatar
^^^ Thanks for the clarification.
Old Apr 10, 2005 | 07:40 PM
BlackM6C's Avatar
Thanks sickone, I will post..
si_driver
Interior
Jul 25, 2015 09:22 AM
vstypicals
Jul 20, 2015 10:55 PM
brian_z
Jul 20, 2015 01:30 AM
