Passanger seat not moving
Old Apr 15, 2005 | 11:03 AM
G30FizzleNYC's Avatar
When I used to lift the lever on the side or back of the passanger seat it would move foward....it does'nt any more did i turn something off?????
Old Apr 15, 2005 | 11:20 AM
Knightt's Avatar
Do you have the 2005? Have you tried pulling the lever AND push the back of the seat forward?
Old Apr 15, 2005 | 11:51 AM
masetodd's Avatar
I had the same problem in my 2003. During the first year I had it, the seat would move in fits and starts, and then it stopped working altogether. Mysteriously, it started working again a month or so later, and it hasn't failed since. It's probably a loose connector to the motor. Try calling the dealership and asking one of their tech guys - I'm sure there's been others with the same problem.
Old Apr 15, 2005 | 12:13 PM
giddyup69's Avatar
do u mean the backrest tilting forward or the whole seat moving forward? i noticed on my '05 that sometimes when i pull either the side or back handle the backrest doesn't move forward. if i fiddle around with it a bit and put slight pressure on the backrest it then releases and tilts forward. then i press the seat forward button and the whole seat moves forward via the power motor.
Old Apr 15, 2005 | 12:22 PM
neffster's Avatar
put the parking brake on and your problem should go away.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Learned Hand
Oct 1, 2015 09:02 AM
doakley92
Sep 25, 2015 12:58 PM
