HELP: Dash Paint Interior
Old Apr 16, 2005 | 09:00 AM
luv2drive's Avatar
20 Year Member
Question HELP: Dash Paint Interior
Guys,
I have a 04 coupe DG with grey interior. The paint (grey metalic) on the part where the instrument panel is located has rubbed off. This was due to my Radar detector power wire which was resting against the side of the instrument panel "pod". The wire goes from the detector to my cig lighter. I can't believe it has rubbed the paint off. It is barely touching the panel and the wire does not move at all. Is there touch up paint? Has anyone else had issues with that paint rubbing off?
Many thanks in advance.
Old Apr 16, 2005 | 10:27 AM
htownboy's Avatar
Originally Posted by luv2drive
Guys,
I have TB 6MT w\Graphite interior and have the same problem; the paint hasn't rubbed off but I was cleaning the dash and noticed the wire had rubbed a noticable shiny spot there... I've been rubbing it when I clean and its getting less noticable; I'm glad I saw it in time or it would have rubbed through.
My buddy at V&V paint and body said he could mask it off, spay some paint on there, sand alittle and it would be like new... I'm gonna' leave it like it is for now, no one notices but me.
I wish I had more to add that would help but I do not, so I am qurious to see what kind of replies this thread will get.
htb
Old Apr 16, 2005 | 10:36 AM
Sickone's Avatar
If I remember the parts in 03/04 were plastic - painted, you might want to call a dealer and see if they have touch up.
Another option is to gets the pieces for an '05 which are actually brushed aluminum.
I think they are the same (Don't take my word, please check before spending money) I don't know how much they cost, or how hoard to install - some of the guys that have done the Double DIN kit should be able to answer the insall part.
Old Apr 16, 2005 | 11:07 AM
htownboy's Avatar
That part in the 05 is also plastic; the same exact plastic.
htb
Old Apr 16, 2005 | 01:35 PM
AustNMike's Avatar
just a thought, and I could be wrong, but I would bet that the problem is not from the wire moving and rubbing, but rather from the sun heating the black cord and the heat from the cord "burning" the plastic.....just a guess tho....sucks, I have my cord in the exact same spot, and I'm in TX....100+ in the summer....time to bury the wire...
Old Apr 16, 2005 | 02:52 PM
Sickone's Avatar
Htownbot - no the part (surface anyway) is not plaastic in the 05, it is brushed aluminum. Aside from it being printed, and the fact that I verified in my car, i have seen the 03/04 they don't even look the same.
Old Apr 16, 2005 | 05:05 PM
luv2drive's Avatar
20 Year Member
The issue with my car is not the metal like part but rather the part around the speedo... you know the outter part of the whole pod that moves up and and down when you tilt the wheel.
Old Apr 16, 2005 | 09:52 PM
Sickone's Avatar
duh - sorry, I misunderstood. I thought you were talking center console... my bad.
Old Apr 18, 2005 | 01:33 AM
KAHBOOM's Avatar
There is a site somewhere online that sells the exact color for the
graphite interior of the car. Try doing a google search for "Leather dye Infiniti" or something of that nature.
Old Apr 27, 2005 | 02:00 PM
luv2drive's Avatar
20 Year Member
Smile Satisfaction!!!
Just to let you guys know Infiniti via the warranty has agreed to repaint that area of the "pod" dashboard. The dealership has a guy that comes in once a week to "fix" used car interiors as needed. I am going to buy a new power cord for my radar detector and also move it so that the cord does not touch the outside of the instrument pod. Many thanks in advance to all those who offered opinions!!!!
Old Apr 27, 2005 | 06:37 PM
htownboy's Avatar
I ride with my buddy in hi 05 twice a week and your mistaken, man you must be thinking of a different part... The part is the same, just no indention for the clock...
You must be talking about the center stack.
Old May 1, 2005 | 03:49 AM
luv2drive's Avatar
20 Year Member
wow... I can't believe there is that much confusion about this!!!! OK... here we go.... look at dash... see speedo and tach and gas and stuff... now that is the pod that moves up and down when you tilt... now... that whole thing is painted on outside... not the center stack...not where clock is.. hope that helps
Old May 1, 2005 | 06:05 AM
htownboy's Avatar
Thanks for clearing that up...
Old May 1, 2005 | 09:24 AM
RBull's Avatar
Rated M
Can you tell me if this guy who repairs interiors is with a company called Autoqual?
Old May 11, 2005 | 03:44 PM
luv2drive's Avatar
20 Year Member
Update On Dashboard Pod Paint Process
Update: I dropped call off at dealership and the vendor who paints/fixes interiors came by and said he can not do it because it has a metalic finish Does anyone know where I can get the paint for the outside finish on the dash pod or give me some ideas on how to fix the problem. If you read my original post you can read about the issue I am referring to.
Just a note: I saw the 05 coupes at dealership and it appears that on the 05's the outside part of the dashboard pod is not same as the 04/03 models.
Thanks in advance.
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
