Got brakes done, and now a dangerously hard petal? help!
Old Apr 23, 2005 | 04:37 PM
Sig's Avatar
Sig
Valid point, I stand corrected.
Old Apr 23, 2005 | 04:40 PM
CKwik's Avatar
Originally Posted by chuckd05
How would i check the vacuum check you were talking about?
I'm not sure where exactly they located it in the G, but it should be anywhere between a vacuum source(intake manifold) and the brake booster. Usually it's a small cylinder barely larger than the line to the brake booster itself and is attached somewhere in-line witht he brake booster line. To check it, you can simply add pressure from the intake manifold side and see if it holds. It should only allow air to go through it from the booster side.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
