Q. on installing a radar detector.
Old May 1, 2005 | 01:32 PM
Gslice's Avatar
Question Q. on installing a radar detector.
I want to install a Valentine 1 radar detector in the near future (no tickets yet, and I wanna keep it that way).
My question to those of you with detectors is: "How did you mount and wire them?" Did you just plug it into the cigarette lighter port in the front console, or did you hard-wire it into the car somewhere (fuse box, maybe?)?
I'd like to know how difficult it is to hardwire it into the car and conceal the wiring. I don't feel too good about removing the interior paneling to hide some wires.
I found an article about doing a "stealth install" of a V1 in a G35 Sedan, but that was way too involved for me. I'd like to just stick it onto the front windshield, but avoid plugging it right into the dash (which looks tacky), and minimize the visible wiring.
Any experience in this, guys? Thanks!
Old May 1, 2005 | 01:59 PM
Speedoholic's Avatar
G (enie) FUNK ERA
I hard-wired mine (passport 8500) via the fuse box (located by the driver's side kick plate - by the dead pedal to be exact).
Ran the wire along the head liner, and down in the A-pillar to the fuse box.
Old May 1, 2005 | 02:19 PM
ZeroGen's Avatar
Omega Enthusiast
There's a few posts on this already. Try doing a search in the DIY or electronics section for the exact details.
I hardwired my V1 in my G coupe and ran the cord inside the headliner next to the windshield down inside the driver side A pillar (need to remove the cover, pops right off) to the fuse box and tapped into the cigarette lighter fuse. Also, for ground, I used a screw that screwed into bare sheet metal.
It looks clean and can't tell that I have a wire running down into the fuse box. My radar is mounted above to the left of my rear view mirror. You can mount it to the top right of the rearview mirror if you can't fully extend the driver side visor.
Old May 1, 2005 | 03:17 PM
hogboy's Avatar
I mounted my unit on the passenger visor. I tucked the wire behind the headliner, side pillar and under the dash. I tied into the wires at the back of the ciggy lighter after pulling up the trim ring around the shifter. It's all hidden and is switched so when I start the car the detecor powers on.
Old May 1, 2005 | 04:05 PM
shooter's Avatar
It's not the critic......
i mounted mine on the rear view mirror.....pulled power from the mirror wires and did not have to run wires anywhere
https://g35driver.com/forums/interior-exterior/50656-escort-passport-8500-mounting-options.html
Old May 1, 2005 | 04:09 PM
GRider35c's Avatar
G, remember that the copper can still pace you, so its not 100% foolproof!
a friend of mine got a ticket this way, and he has a V1 in his G...
Old May 1, 2005 | 04:45 PM
Gslice's Avatar
Wow, thanks everyone. Looks like I am gonna be a big ole copycat and try to run it inside the headliner and tap the fusebox.
Old May 1, 2005 | 05:24 PM
Hotrod's Avatar
https://g35driver.com/forums/showthread.php?t=50656
I did the exact same thing it took like 15 minutes to install and the best part is you dont have to hide the wires since you get the power right from the mirror.
Old May 1, 2005 | 05:34 PM
Gslice's Avatar
More details and/or photos of the mirror method would be helpful. Did you guys have to make a custom bracket like the guy did in the "stealth install" for the V1 in the sedan? Cause that's just too involved (and in my opinion, crappy looking) for me.
Old May 1, 2005 | 10:22 PM
shooter's Avatar
Gslice.........click on the link in my previous post and in that thread i give you the guys name you can order the bracket from over at 350z.......mike......thats pretty much the whole install.......buy the bracket, bend your suction cup bracket to 90 degree, install the bracket on the mirror post and then you have the wiring, which i have instructions for that in the link as well........let me know if you need anything else
good luck!
Old May 1, 2005 | 10:25 PM
Gslice's Avatar
good luck!
Thanks, shooter - much appreciation!
Old May 2, 2005 | 12:08 AM
supra2k's Avatar
lol just get a wire and hardwire it to your fuse box. remember green is grounding
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
