Brembo brake question
May 2, 2005 | 06:22 PM
I have around 7000 miles on my 04 coupe, my brembo brakes feel as if they are getting warped every time I stop....or need to be cut...any body going though this. any feed back please.....
Reply 0
May 2, 2005 | 10:14 PM
you mean there is a vibration when you are applying the brakes? if so, you may have warped your rotors, and cutting them, which is really expensive, is not really that great. you dont want to machine down just one side....i would just replace the rotor. however, it could also be a wheel balancing problem, or even a loose set of wheel nuts, so check those out as well. good luck.
Reply 0
