Bugs on the Car
Old May 7, 2005 | 02:53 AM
Ferrarimanic360's Avatar
Bugs on the Car
What do u think is the best way to remove bugs stuck to the front of the car....without scratching it!!! Also i have a black coupe and i always seem to have bugs and little mosquitos "dancing" around on my car....has this happened to anyone else
Old May 7, 2005 | 07:35 AM
DrPJM1's Avatar
I live in the country and bugs are everywhere starting in March.
Drove yesterday from Chicago & the G was plastered when I got home. I take the G to a car wash with a pressurized hose. I soap all the car 1st, then do the top, sides and rear and finally go back to the front to remove all the exoskeletons and guts. Works like a charm.
There are bug/tar cleaners in the stores, but this has worked best for all our cars.
Old May 7, 2005 | 08:40 AM
GeeWillikers's Avatar
Walking The Fine Line...
You just cleaning the front or the whole car?
I use a hose with low pressure and rinse the front so as not to spray the entire car.
After I soak the little monsters good, I get a small microfibre and wash each one off using a light flow from the hose to provide a constant rinse. I turn the microfibre very often and rinse continually.
Works great. No problems. She gets a rinse everynight before I put her in the garage.
Careful with the love bugs - they are acidic and will etch your paint if left on too long.
Old May 7, 2005 | 09:35 AM
Hotrod's Avatar
A high quailty wax and even a coat of QD after washing helps those little suckers from sticking to the car well. You should be able to wash most of the stuff off with just a good flow of water and a little soap. I would soak them good first so that most of it flows off so as not to scratch the paint. Good Luck.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
nervseele
Jul 17, 2015 11:21 PM
