Clear Bra And Tire Shine
Old May 9, 2005 | 03:50 AM
boy35's Avatar
Hey guys i heard if you had the clear bra on and you use tire shine it can damage the sides of the clear bra by the wheel well and turn it yellow. has anyone heard of this happening? and need help picking out a color...dg with stone or Ip with stone??????? which would you pick?
Old May 9, 2005 | 04:28 AM
TheGest's Avatar
Gangster Member
i got quoted 700 installed for clear bra, whats the point, i rather repaint my stuff
Old May 9, 2005 | 08:57 AM
RBull's Avatar
Rated M
Some makes of clear bra are clear coated so there is virtually no issue with yellowing.
Old May 9, 2005 | 11:44 AM
gDriven's Avatar
You are probably talking about the 3m clear bra. I've had problems with it yellowing before. It doesn't really have anything to do with what you put on it. I was told that it is the property of the adhesive that makes it turn yellow over time. That's why I switched to someone using Venture clear bra.
Old May 9, 2005 | 02:06 PM
P_Diddy's Avatar
The older 3M clearbra had a problem w/ yellowing. The new formulation is supposed to be much better. Some tire shines sling off the tire and onto the car body though. i'm sure the oil is not very good for the paint.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
linedr89
Aug 17, 2015 05:11 PM
underworld
Aug 6, 2015 01:36 PM
