Some might know, some might not....
Old May 9, 2005 | 11:21 AM
WinglessG's Avatar
Some may already know, but for those who don't...
With the car off, you can put your key in the door and turn/hold it left or right to automatically close/open your windows... cool "never mentioned" feature especially for those hot summer days.
Old May 9, 2005 | 11:23 AM
GuLater's Avatar
If you hold down the unlock button on your remote for about 5 seconds the windows will roll down as well
Old May 9, 2005 | 11:24 AM
Poptarts's Avatar
Swerving and Weaving
edit: ^^^^^^^^ what he said
Old May 9, 2005 | 11:29 AM
SilverII's Avatar
Also, there is a shift lock key in the boot near the spare tire.....(For AT)
Old May 9, 2005 | 01:06 PM
neffster's Avatar
Also if you press the lock button on the OEM remote twice within 2 seconds the windows will roll up.
...with the kptechnologies window roll up module of course.
Old May 9, 2005 | 01:14 PM
Speedoholic's Avatar
G (enie) FUNK ERA
That is if you have the KPTechnologies chip
Otherwise, you'll have to run back to the car and stick the key in...
Old May 9, 2005 | 01:15 PM
Sundeviljay's Avatar
Silver...what is the shift lock?
G (enie) FUNK ERA
Never mind... just saw your wise a$$ color theme going there... LOL
Old May 9, 2005 | 01:17 PM
G (enie) FUNK ERA
Basically is you don't have the key in the ignition you can't switch gears (there is lock on the gear box). The lock bypass (looks like a groove where the boot is) that will let you bypass the lock without needing the keys.
(for towing purposes for example).
Old May 9, 2005 | 01:19 PM
SilverII's Avatar
what he ^^^^ said
Old May 9, 2005 | 02:48 PM
GuLater's Avatar
This this true that you need the KPT chip in order to make windows roll up?
Old May 9, 2005 | 03:25 PM
lkmbrd's Avatar
Good thread. What other cool, little-known things are there?
Thanks.
Old May 9, 2005 | 03:33 PM
lucidazn's Avatar
There is a revlimiter on the 05
Old May 9, 2005 | 03:34 PM
lucidazn's Avatar
A trunk lock switch on the side of the glove compartment'
Old May 9, 2005 | 04:25 PM
RBull's Avatar
Rated M
and if you turn the key the car engine will start.
