Is this normal? question for 6mt owners
Old May 9, 2005 | 10:14 PM
Wildcn's Avatar
question for all ur 6mt owners, do you feel a knock from the car when u suddenly step on the gas hard?
i have a 05 6mt, the tranny seemd wired, if i m goin 20 mph in 2nd gear and suddenly step hard on the gas, the car accel after a stronge knock from the car ( hard to discribe where it's from ) is that normal? i thought only auto trany dose that.
Old May 9, 2005 | 10:28 PM
Madelinot's Avatar
04 here, nothing of that sort... Have it checked out.
Old May 9, 2005 | 10:32 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
I have '04 6MT and can not feel what you have explained Have your G checked out
Old May 9, 2005 | 10:36 PM
phishman's Avatar
I've driven a lot of manuals and this car seems different from the others, although this is my first asian car. Ive had mine for about a month and much of the clatter has gone away. Are you sure its coming from the engine compartment? Can you feel it or hear it?
Old May 10, 2005 | 09:59 AM
Wildcn's Avatar
cant hear any sound just can feel it and it's not from the engine compartment, it's more like something hit from the back.
it happens about little less than full 1 second after i step on the gas and the power kick in after the knock.
Old May 10, 2005 | 10:03 AM
TwilightG's Avatar
Do you have something rolling around in your trunk?
Most of annoying rattles I hear in my car turn out to be the crap I leave in my trunk or back seat.
I'm not trying to be sarcastic, just covering the basics.
Old May 10, 2005 | 10:22 AM
Wildcn's Avatar
got 2 towels one bottle of Z6 and one bottle of z10 in the trunk.
couple piecese of A4 sized paper one stuffed animal and some cookie in a zipped bag on the back seat.
and the knock IS from the power train
Old May 10, 2005 | 10:25 AM
clokwork's Avatar
Cmon Son!
has the clutch fully engaged when you hear the knock?
Old May 10, 2005 | 10:50 AM
Wildcn's Avatar
clutch has fully engaged, also, it happens to almost every gear,
I CANT HEAR THE KNOCK, I CAN FEEL IT,
Old May 10, 2005 | 10:57 AM
GT-Ron's Avatar
I know this could be a lot of things, given the lack of info and second-hand observation... ...but does it feel like it's something unbinding... ...like a release of stored/built-up energy/tension (such as a binding sway bar, etc.)? Just trying to pin down the feel between something like that^ or something more along the lines of a mechanical-disengaging feel (LSD issues?).
I'm sure you'll get enough help around here to identify it.
Old May 10, 2005 | 11:13 AM
Wildcn's Avatar
actuelly, ya, something like that,
Old May 10, 2005 | 11:22 AM
Hotrod's Avatar
First off I don't know why you would step hard on the gas at 20 in second gear I would think that the rpm's are way low and the engine is no where near its power band. That being said before you step on the gas hard did you have your foot on the gas or was the car coasting/slowing in gear ? If the car was coasting or slowing down with the car in gear and the clutch was fully engaged (this would cause the entire driveline to be unloaded) I would suspect that what you hear is the backlash in the Diff or the U-joints. Neither are uncommon in this type of situation.
Old May 10, 2005 | 12:15 PM
Wildcn's Avatar
please read before u post!
when u goin at 20 mph in 2nd gear rpm should be around 2k, that's not low for 2nd gear!
AND i DIDNT hear a knock i FEEL the knock!
Old May 10, 2005 | 12:17 PM
RBull's Avatar
Rated M
'04 here too. No sound of that sort from mine.
No matter what you hear from this forum I suspect it's dealer time for you my friend. If it happens all the time in all gears it should be easy to diagnose right on the hoist.
