"SLIP" light permanently on
Old May 16, 2005 | 09:14 AM
Balzz's Avatar
I've noticed that when I inadvertantly spin the car, the SLIP light stays on and VDC will not turn on until I restart the car. Is this normal behaviour? I can't find anything in the manual about it. This is during skidpad training and on an autox course btw...I'm not doing this on streets.
Old May 16, 2005 | 09:39 AM
Hotrod's Avatar
do you have the VDC on when you are doing this?
Old May 16, 2005 | 09:44 AM
Balzz's Avatar
Off. VDC won't turn back on when the slip light is on. I have to restart the car for VDC to be on aftewards.
Old May 16, 2005 | 11:11 AM
ozracer01's Avatar
Yeah thats normal. VDC is still activated even if you turn it off. I think the VDC control module gets confused when it keeps trying to stop the slippage, and you keep slamming the gas in order to do a donut.
Old May 16, 2005 | 11:17 AM
SilverII's Avatar
yup... i've heard that it is normal. I have never tried it myself. They say to "actually" turn off VDC is to pull the abs fuse...
Old May 16, 2005 | 11:45 AM
Pearlcoupeg35's Avatar
That happens to me every now and then when i turn my vdc "off" and get crazy...on my navi it says take oyur car to the dealer becasue your vdc is blah blah blah....and the slip light stays on too - so i just "reboot" and everything is ok.....until next time i wanna do figure 8's! hahaha
Old May 16, 2005 | 12:33 PM
S-Tuned's Avatar
gtr proto test driver
if you turn your car back on and it still has the slip thing on, bring it into infiniti i had the same promblem last year when my car started to spin in the rain, slip came on and came on again when i turned the car back on
Old May 16, 2005 | 12:58 PM
Msedanman's Avatar
O.F. Administrator
Yeh bro, it's designed to do that, and will reset after shutting off and restarting.
C.
Old May 17, 2005 | 10:18 PM
BirdMan's Avatar
Yea pretty much what everyone else said. Basically when you push the VDC button, the VDC itself still remains on and isn't completely turned off. What the reasoning is for this I don't know. When you pull those spins and the SLIP light remains on, it means the VDC is totally shut off. You'll notice those first couple spins the VDC will fight it, but once the SLIP light stays lit spinning will be much easier because the VDC is disable. Turn the car off then back on, and the VDC is operating as usual.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Jnm07
Sep 5, 2015 01:16 AM
zcherub
Aug 30, 2015 05:04 PM
