HELP!! 80mph+ car is shaking.....!!!
Old May 22, 2005 | 05:41 AM
narkotic's Avatar
If it were a hub centric ring problem, you'd have the wobbling all throughout the speed. If it's only as high as 80mph and above, i can guarentee it's wheel balancing.
Old May 22, 2005 | 05:51 AM
RBull's Avatar
Rated M
Wheel balancing if its only at higher speeds like that. Doubtful its anything else if you can't feel it at lower speeds.
Old May 22, 2005 | 06:47 AM
mc2's Avatar
mc2
Hmm. i dont think this is entirely true.. On my MR2 it would only shake at speeds in excess of 70. And i knew for a fact it was due to the aftermarket wheels and no hubcentric rings.
Just speaking from my experience though.
Old May 22, 2005 | 09:40 AM
G Thizzle's Avatar
being that it is sunday i will need to find a shop that can do it.... how much do the hubcentric rings run??? just in case i have to get some.... hope it is just wheel balancing....
Old May 22, 2005 | 11:48 AM
G Thizzle's Avatar
I took my car to tire kingdom and they re balnced my wheels.... they were way off!!! thanks for all the insight everyone... jumped on the 10fwy doing about a buck twenty....no shaking or vibrating!!!!
Old May 22, 2005 | 09:04 PM
Hooman6MT's Avatar
20 Year Member
rule of thumb if over 80mph shaking it's usually your front wheels that are out of balance. If it's lower speeds and not at higher speeds then it's your back wheels.
Also most wheel spacers under 15mm will cause shakes. Some of the 10mm ones are good.
Hooman
Old May 22, 2005 | 10:51 PM
DanielEshaghian's Avatar
balance
Old May 22, 2005 | 10:58 PM
G Thizzle's Avatar
Originally Posted by DanielEshaghian
balance
yeah alredy done
Gee Im Fast's Avatar
balance
Yea bro....its been done lol.
Old May 22, 2005 | 10:59 PM
Whoa we posted that at the same time...wierd.
Old May 23, 2005 | 12:01 AM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Your wheels need to be Re-Balanced make sure they "High Speed" balance
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
