HELP!! 80mph+ car is shaking.....!!!
Old May 21, 2005 | 08:48 PM
G Thizzle's Avatar
Exclamation HELP!! 80mph+ car is shaking.....!!!
I just got my new wheels and tires...
19x8.5 & 9.5 HPD-10 w/ Hankook ventus 245/35/19 & 275/30/19
Lowered on 350z Tein H-techs.......
i got on the freeway for the 1st time with the new wheels and tires and i noticed that the car started shaking and the steering wheel was vibrating when i hit about 80-85.... i slowed down to about 70 and it was fine....i havent gotten an alignment yet, could that resolve the problem??? i was going to wait until i hit 300 miles but the shaking and vibrating is killing me!! please help!! thanks in advance!!!
Andrew
Old May 21, 2005 | 08:54 PM
Need4SPEED05's Avatar
Your running the same width tires in front and back and on 8.5 and 9.5? The shaking could be due to the alignment or the wheels need rebalancing. No don't wait for 300 miles, do it right now so you won't have to buy new tires next week.
Old May 21, 2005 | 08:57 PM
G Thizzle's Avatar
My bad i edited my post.... i meant i have 275/30/19 on the rear.... so you think an alignment would fix it???
Old May 21, 2005 | 09:11 PM
GXCLUSIV's Avatar
Make sure wheels/tires are balanced, and check to verify if the wheels you bought may require hubcentric rings, without it may cause the shaking/vibration.
Old May 21, 2005 | 09:16 PM
Msedanman's Avatar
O.F. Administrator
4 wheel alignment and a good balancing. Do it now, bro.
C.
G Thizzle's Avatar
when i bought the wheels they came mounted and balanced.... i am not sure if they need hubcentric rings... offset is +38 all around.... pretty basic set up... i hope it will be an easy fix.... thanks GXCLUSIV....
Old May 21, 2005 | 09:17 PM
roko's Avatar
1.Hub centric rings?
2.Alignment?
The shop that mounted must have balanced, do you see wheel weights?
Old May 21, 2005 | 09:26 PM
G Thizzle's Avatar
2.Alignment?
weights are on the rims... i seen them.... so what do you think it would be????
Old May 21, 2005 | 09:27 PM
narkotic's Avatar
If it's only during a certain MPH, it's the balancing. They need to be re-done.
Old May 21, 2005 | 09:37 PM
G Thizzle's Avatar
i mean it is when i hit 80 and over.... when i am doing city driving they are fine.... so i should just get them re balanced???
Old May 21, 2005 | 09:45 PM
Gee Im Fast's Avatar
I'd have everything re-done to be sure. I mean you might as well while the wheels are off the car right? It would suck to get an alignment and realize the problem is still there due to a balance or something...if none of this fixes the problem, it could be a slight negative offset...
Old May 21, 2005 | 10:33 PM
mc2's Avatar
mc2
my guess will be hub centric rings.
Old May 21, 2005 | 10:51 PM
G Thizzle's Avatar
on a +38 offset??? how much do they run and where do i get them from???
Old May 22, 2005 | 12:07 AM
IS300TOG35's Avatar
► Matt ◄
First you need to verify thats the problem. If you dont know what the hub is bring it to the shop and ask them if you need hub rings. If you do, call the wheel manufactuer and they should be able to get you a set.
If it makes you feel any better I put my rims on friday and driving 80+ i get slight vibration over what I had with my stock rims. I think my problem is I have spacers on my front rims and even though they are hubcentric, spacers still tend to give minor vibrations... But hey look on the brigh side. 80 MPH is speeding and can get you in trouble. You shouldnt be going over 70 mph anyways, your car is just trying to protect you
All joking aside just get it checked out, unless you bent a rim already which is unlikely then a shop wil be able to resolve the issue.
Matt
Old May 22, 2005 | 12:10 AM
Rookie84's Avatar
Get an alginment. After a drop, the alignment goes out of spec and it can cause some vibrations and make the car unstable.
