HIDs color
Audi's have HID projectors which give it a nice color band at the light horizon. Even though the HID bulb is at 4300k, the color band has a large solid blue'ish section that we usually see. Often times, people will get 8000k HID bulbs to immitate this color in the color band, but by doing so, the high color temp doesnt light up the street very well. I would never go any more than 6000k... but thats just me. IMO, anything beyond that is loosing ALOT of lighting to a point that normal halogen might be better! If you want the same color as the Audi's, get HID projectors and retrofit them into the headlights of your car.
Originally Posted by Asianicboi
so if we want a more bluish low beam, we should get 6000k?
OEM hids are usually 43000k, and I think the S2000's is 47000k. Alot of these HID setups look so nice because of their projectors that they have. So far, the S2000's projector is the best! Its bright, spreads wide and evenly, and the horizon cutt-off has a nice color band and also sharp!
Also, HID bulbs tend to "fade" over time. After alot of usage, the color temp of the bulb being used will become cooler after time. Meaning it usually becomes bluer.
I have 8000K and there not that bad. 6000K are not as Blue but give better light across the road/field. I accept the lose of brightness for the look, JMO
You don't need a full HID kit, just a pair of bulbs. The bulbs you need for your HID is D2R, make sure to get that, NOT D2S, as they are diffrent.
I got my bulbs for around $130 I think.
To make your fogs match your low beam, you need to pick which HID you want first, then get a bulb with the closet color rating.
Originally Posted by AznRacer305
one question i need to know what kind of bulds i need to have for my fog lamp to look just like my lowbeam?
its been a long time since I've seen them side by side.
What company bulb are you using for your G?
