is bose upgrade worth it?
Old Jun 6, 2003 | 08:03 PM
StudlyMobile's Avatar
wanted moonroof, but figured stock stereo was good enough. so didn't order premium. figured why pay for options didn't want.
now reconsidering. does the bose REALLY make a diff?
Old Jun 6, 2003 | 09:23 PM
BONDg35c's Avatar
Re: is bose upgrade worth it?
I can't comment on the stock base model sound system since I've never heard it. But from my experience with a brand new Bose system in another car, I was completely UNDERWHELMED.
Yet, because I wanted the other features of the premium package, I did order it and got the upgraded Bose system. Again, I'm underwhelmed and I am no audiophile---I barely know where the on/off button is.
Apparently, in the ten years since I first got this supposedly premium sound system, Bose has not improved and my taste has changed. In between, I had another car that had a base stock system that was phenomenal even tho there were upgraded systems one could buy.
Unless the base system is awful (and even if it is), I'd not choose the Bose as an upgrade. I'd rather go to some audio shop and hear what they've got to offer. I'd be willing to guess that for not too much money and depending on the size of your wallet (or the importance of sound in your car), you could get a very good system.
Good luck.
BONDg35c
Old Jun 6, 2003 | 09:57 PM
ReDRoK8's Avatar
Unless you plan to upgrade the system imediately I the upgraded Bose is a must. I consider myself a very discriminating audiophile and the Premium Bose is barely tolerable. I have never heard the standard but if it's worse than this I'd kill myself. I will probably end up upgrading it. But for now it is better than the standard. Good luck.
-Jason
Laser Red '03 6MT
Old Jun 6, 2003 | 11:35 PM
i did order the moonroof. was planning on it from the start.
now, i'm no audiophile, and also not to enthralled with the options in the premium package. i guess cost wise, i might be better off just getting the moonroof, and if the stereo is that bad, go to some shop and get one.
does the bose come with an extra speaker, and would i have to get that too installed?
also, would the installation, even slightly mar, the "new car"
Old Jun 7, 2003 | 12:09 AM
tec243's Avatar
Studly, if you're no audiophile and didn't care for any of the other premium package inclusions, I think you made the right choice. You're $900 (cost of Bose upgrade) closer to an upgrade of your own choosing. Rambo has the base system, I believe, and is happy with it. ...dean
Seattle 'Eastside' area
'R' Order - IP/Graphite 6MT Coupe; Prem., Nav. & XM [img]/w3timages/icons/smile.gif[/img]
Old Jun 7, 2003 | 11:51 AM
dave_c's Avatar
It is worth it?
NO
Invest the money in better speakers and an amp.
I've read about 100 posts on this issue and its about 99% against the bose system.
Q Order, VIN issued, somewhere at sea
Coupe 6MT
Laser Red
Old Jun 7, 2003 | 12:01 PM
Linh's Avatar
1 more against the Bose. It has a little bit of bass but is completely lacking in clarity.
Old Jun 7, 2003 | 01:36 PM
lostin310's Avatar
If you don't want the premium package features, skip the Bose. For $900 you can buy a 2 channel amp and replace the front speakers with something really nice then grow the system later... Or if you aren't into high end car audio; replace the front speakers with some mid-level components and the rears with some mid-level coax. Run them off a decent four channel amp (make sure it has RCA outputs for a sub amp later). You can do this for under $1100 installed, and may be content with the results and not even want a sub... Or you can throw a sub any time you have the cash.
Old Jun 7, 2003 | 04:17 PM
Edretti's Avatar
The bose system does not have a sub that I know of. Most of the bass is driven by the 6x9's on the rear deck. I can only recommend this, the Bose system alone TO ME is not sufficient and not that desireable. However I added a 10" sub and a 280W amp for it and it made the difference in the world. Granted I spent $500.00 for everything to be satisfied I think if you spend a little bit more you can upgrade the entire system for under $1000.00 and have a way better sound system then Bose.
Edretti
2003 Nissan 350z Track Daytona Blue
2003 Infiniti G35 Coupe 6mt Loaded Brillant Silver
Old Jun 7, 2003 | 05:51 PM
COUPEDIT03's Avatar
Probably more than $1G to get it all done...
Im talking about using quality components...Alpine, Kenwood, JL,...NOT Jensen, Blaupunkt, etc..
"Dont start none, won't be none"
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
Visionnn
Oct 3, 2015 05:16 AM
