dropping clutch with vlsd
Old Jun 17, 2005 | 11:22 PM
Nickk6's Avatar
I am not use to my car having a LSD. Today off the line I launched extremely hard, the RPMs hit pretty high probably in the 5-6k RPM range, I was trying to let the clutch out, but it just stuck. The car finally took off about 5 seconds too late as the lsd finally grabbed. I couldn't shift out of first gear as the clutch was stuck in. Now my question is, How much damage does this to the LSD (I know the clutch took its fair share of abuse from that), I think its happened 3 or 4 times now. Anyone with mechanical knowledge of the LSD, please throw me a bone.
thanks
Old Jun 17, 2005 | 11:33 PM
636Racer's Avatar
it's not the LSD, the hydralic clutch slave SUCKS!
Old Jun 18, 2005 | 01:44 AM
Nickk6's Avatar
So what is getting tore up while my engine revs to the high rpm range and the car does not move?
Old Jun 18, 2005 | 03:37 AM
Msedanman's Avatar
O.F. Administrator
.....definitely the clutch that's taking the beating.
Talk to the dealer about a fix.
C.
Old Jun 18, 2005 | 04:07 AM
Nickk6's Avatar
a fix? The clutch should be able to handle a few scorchings right? Car drives fine, but just curious about the LSD because my last RWD car would spin the back tires if I launched the RPMs high enough. My FWD car would easily smoke the front tires or if I slipped the clutch I could get really good launch out of it. I thought the LSD was absorbing the wheel slip because I've never had this happen in any of my cars without LSD. Traction Control was off.
Old Jun 18, 2005 | 08:52 AM
kenchan's Avatar
Is there a mechanical lock that prevents clutch dumps at high rpm?
Old Jun 18, 2005 | 07:44 PM
Klubbheads's Avatar
R u sure vdc was off?
Old Jun 19, 2005 | 03:46 AM
Nickk6's Avatar
Yeah, I wish it were on, at least I would have just been tearing up the brakes. But since I posted this thread, my car still smells like clutch when I am done driving it, even when I am not driving hard.
Old Jun 19, 2005 | 04:49 AM
EricIsKlumzyee's Avatar
the car will NOT let you drop the clutch at a high RPM.. dont ask why iono but its like this on all the 05s.. duno bout 04s or 03s
edit.. lets say ur rolling on 1st going to 2nd and u shif to 2nd but u drop it at 6k RPM.. it wont let u ._.
Old Jun 19, 2005 | 08:11 AM
kenchan's Avatar
so there is a lockout feature. that's a good they dummy proof one already.
Old Jun 19, 2005 | 08:37 AM
paranormal's Avatar
no its not a lock out feature.. the clutch just sucks ***! you either have to let it out really quick or else you will just burn it up and it wont goo.... 05's transmission sucks
Old Jun 19, 2005 | 10:28 AM
Balzac72's Avatar
G SQUAD
I have the same problem with my car. Although you'd think this was supposed to HELP you, it actually burns the clutch, so I wonder why infiniti did it. Its a shame that the clutch just won't catch, so you can give the engine and car a good workout. I guess it doesn't matter much though, since you get better speeds dropping at 4500rpm anyway.
Old Jun 19, 2005 | 10:54 AM
izmir41500's Avatar
G35driver Addict
i know there's a clutch dampening device on the is300's that can be removed, is there something similar on the G35 possibly?
Old Jun 20, 2005 | 03:26 AM
Nickk6's Avatar
The trannys are different?
Old Jun 20, 2005 | 10:42 AM
GT-Ron's Avatar
That would be nice.
