Power Window Malfunctioning
Old Jun 24, 2005 | 02:45 PM
Johnny Blaze's Avatar
The power driver window in my '03 coupe has been malfunctioning. Sometimes it will not go up after closing the door. Other times, the window will not actuate when the button is depressed or pulled. It also has jerky motion when it does work. Has anyone else experienced this? Was it the motor or was it something else?
Old Jun 24, 2005 | 03:04 PM
madchef's Avatar
Sounds like your window regulator is on the fritz. There might be a TSB on this, but I'm not sure...
Old Jun 24, 2005 | 03:53 PM
Msedanman's Avatar
O.F. Administrator
Yes a faulty regulator or motor. The issue is well know at the dealers.
C.
Old Jun 24, 2005 | 06:33 PM
aszatk01's Avatar
just got mine fixed a week ago. dealership fixed it for free even though i'm out of warranty. nice of them--but they know about it. should only take them a few hours
Old Jun 24, 2005 | 06:36 PM
waijai's Avatar
i.love.gold
Both mine went out, and I got both replaced free of charge. It's a known issue.
Old Jun 24, 2005 | 08:48 PM
candyvp's Avatar
Both of my windows regulators have been replaced one at a time. If your window is stuck down you might try lifting up on the window button and with your other hand using a closed fist hit the inside of the door panel lightly by the regulator and the window may go back up (mine did) if it does go up don't lower it until you take it to the dealer.
Old Jun 25, 2005 | 12:09 AM
shipsaeki's Avatar
most likely motor, i change them all the time.
like candyvp said, hit it with a fist with slight force, if it moves when you hit it, it's a motor.
Old Jun 25, 2005 | 03:10 AM
Jetleaf's Avatar
Hey guys what about this. My drivers window goes up and down just fine. However, if the car sits outside when it is 85+ degrees the window goes all the way up and then immediately goes back down to about the halfway position. The only way to make it go up and stop is if I don't use the "one touch auto up" feature. WTF??? I have an 05 6mt with only 2600 miles.
Old Jun 30, 2005 | 09:48 PM
shipsaeki's Avatar
your window motor needs to be reprogrammed. the window motor may have gotten reset somehow. it's common also.
take it to the dealership, or if you want to do it your self, take off your door panel, and where you see the three bolts for the window motor, you will see a black circular sticker. That sticker is hiding a rubber button for the window motor. its a little tough, but hold that down and make sure the window switch is connected and roll the window down first but do not use one touch. Then use one touch and roll the window up. This should reset the motor and it should work afterwards.
Old Jul 1, 2005 | 12:06 AM
vic49's Avatar
i had the same problem with mine going up and then going down half way....i took it to the dealer and they changed the motor on it...
itgogitrev
Sep 23, 2015 07:08 PM
Paragham
Sep 15, 2015 12:04 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
gatorglaze
Sep 10, 2015 12:03 PM
