350z-G35 cpe HP difference in
Old Jun 18, 2003 | 08:26 PM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
Re: 350z-G35 cpe HP difference in
Hey guys,
Ever noticed that both engines have the same redline (horsepower = torque x rpm)???
or how both engines have the same torque max rpm (4800)???
or how they both have the same hp max rpm (6200)???
Do you think it would be possible using the same engine (VQ35) to just "translate" the entire torque and power curves perfectly "upwards".
Not possible. Marketing ploy to uphold the image of the Z. Has anyone read the G test v RX-8 v SVT Cobra- the G posts a better zero to 60 than their Z previously, despite the extra "girth"??? Easy to explain actually- supple suspension helping put the SAME power to the ground.
Cheers,
Derek
DB
Old Jun 18, 2003 | 11:30 PM
Linh's Avatar
There is a truely a two hp differance
<hr></blockquote>lol you'd get a 2hp difference with the SAME car, SAME day, SAME dyno
Old Jun 22, 2003 | 01:33 AM
HateThatBobBarkr's Avatar
pop both hoods, theres a baffle type thing next to the sensor on the G that the Z lacks
hmm
-moooooo
Old Jun 22, 2003 | 02:22 AM
DallyCurtis's Avatar
yes.....
interesting...
hmmmmmmmmmmmmmm
I smell sausages. ??
hmmmm again ...I'm inside downstairs in a office with noone around at 3:20am??? WTF
ohhh well...
if I die from a sausage toting monster ... all the best fellas
[img]/w3timages/icons/tongue.gif[/img]
Old Jun 22, 2003 | 02:53 AM
Christobal65's Avatar
As far as i know the Offical claim from Nissan is that he Z has a freer flowing exhaust then the G35
Proud owner of a 1991 3000GT VR-4
And a Proud Employee of Sacramento Infiniti
Old Jun 22, 2003 | 07:57 AM
suprhulk's Avatar
Definitely a marketing ploy to hype the image of the Z as a true "Sports Car" vs the G "Sports Coupe".
You <font color=red>will</font color=red> get 1 - 5 hp difference between two dyno runs for the same car just 5 minutes (cool down period) apart. What you do is run dynos until you get two runs back to back that have just 1-2 hp difference. Then you select whichever dyno run shows the higher hp as your baseline. Usually the last is not the best since that is when you know you've "dialed in" the car to the dyno.
Also, no two engines are the same off the same assembly line.
Unfortunately for me my G35c has a crank hp of 273.25hp. This was confirmed by doing multiple baseline runs on two different Dynojet dynos by two different "tuners" in two different cities just 4 days apart. (I didn't believe the results of the runs done on the first "tuner's" dyno. The 2nd "tuner's" dyno showed the same results. This "tuner" told me that differences in hp between identical cars are to be expected.)
When I added the Stillen catback exhaust I got a 12.125hp increase bringing my G's hp to 283.375 hp.
So now My G's numbers are up to Infiniti's/Nissan's <font color=red>BS</font color=red> marketing specs.
Screamin' Daemon - L5AT
Old Jun 22, 2003 | 08:15 AM
qirex99's Avatar
what was your RWHP? when you factor the increased loss a 5AT will give you 220-229 should be your range.
BTW Not to repeat myself, but the intake and exhausts are different. I havent been under a G35, but the intake in the G is much more restrictive (and quieter!!) - heck it has a resonator!
ALso, I think a 7HP diff is a pretty *weak* marketing "ploy" - but thats just me. 20HP - thats something....7? no. Just to play devils advocate...is the 20HP diff btw the coupe and sedan real? or a "ploy"?
Old Jun 22, 2003 | 09:11 AM
well according to your restrictive exhaust theory applied in that scenario ... I have to say real ... but that would mean the z has seven horse on the G .. no neccessarily ... the sedan 20 less ??? not necessarily .. just like the same z's tested in one day had 220 and the other 240 something..
who knows really.. its a variable that cannot be measured on a whole ... only individually.
PERIOD
and ... "sayonara"
Old Jun 22, 2003 | 12:48 PM
lowrider's Avatar
The exhaust is not different on a G35, only longer (7 or 8"). The resonator, muffler and Y pipe are the same and pipe diameter is the same (2.25"). Should not restrict power compared to the "Z". (I did however build a dual system for my 6MT coupe). The intake is another story, it does have a resonator. I have ordered the Z's tube intake to replace that, and should have it next week.
Lou
Old Jun 22, 2003 | 01:24 PM
suprhulk's Avatar
Baseline RW HP: Dyno # 1 - 216.4; Dyno # 2 - 218.6;
Baseline RW Ft/Lb: Dyno # 1 - 253.0; Dyno # 2 - 218.4;
Stillen exhaust RW HP: Dyno # 2 - 228.3;
Stillen exhaust RW Ft/Lb: Dyno # 2 - 255.0;
I didn't feel the need to go back to Dyno shop # 1 since I got the same numbers from Dyno shop # 2 who is 50 miles closer to home and charged $15 less.
Note also that the ridiculous torque numbers are due to how an automatic torque convertor works and how one executes a Dyno run/record. (Baseline runs at Dyno shop # 2 did catch the "flash" of the AT but I kept those runs which didn't show the spike. Note that the best Stillen run at Dyno shop # 2 does have the AT's torque spike.)
<font color=red>Baseline run Dyno shop # 1:</font color=red>
<font color=red>Baseline run Dyno shop # 2:</font color=red>
<font color=red>Stillen Exhaust run Dyno shop # 2:</font color=red>
Old Jun 22, 2003 | 06:23 PM
qirex99's Avatar
are you replacing the airbox too? it has a cold air type setup
Old Jun 22, 2003 | 10:26 PM
lowrider's Avatar
No, I'm not replacing the airbox, since it's already a CAI. I have, however, put a K&N Filter in it.
Lou
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
