Concern: 19" Tires
Old Jul 7, 2005 | 11:21 PM
djinferno's Avatar
Originally Posted by aerisolphaln
1K for tires on a car like this is a pretty good deal. You should price out a stock set of tires for an M3, it'll make the G seem like quite the bargain.
i second that
Old Jul 7, 2005 | 11:27 PM
Finiti35's Avatar
FGC South Florida BOD
What makes you guys think M3 tires are so expensive? Unless you're buying runflats, the fronts are the same size as ours and the rears are 255/35 instead of 245/40.
Old Jul 8, 2005 | 12:10 AM
ZeroGen's Avatar
Omega Enthusiast
Check out Bridgestone RE050 tires or Michelin PS2. Both are very good tires - pricey but good.
Old Jul 8, 2005 | 12:33 AM
csdstudio's Avatar
The Bridgestone RE050 is the stock tire on 05 6MT. I took mine off and after 1500 miles of easy break-in driving you can already see signs of wear. Soft tires. On the other hand, my Avons have been on for 3000 miles now and still look new. After break-in, I've been driving a bit more spirited too. 140 treadwear rating is horrible, 360 is miles better.
Old Jul 8, 2005 | 12:47 AM
Finiti35's Avatar
Are your Avons a performance summer tire? I don't disagree with you, but comparing treadwear ratings across brands does not mean a thing.
Old Jul 8, 2005 | 12:53 AM
csdstudio's Avatar
No, ultra high-performance all-season. Was just pointing out that you don't have to settle with tires that wear out fast. My initial mileage comparison does prove that these tires will last 2 to 3 times longer, at a small sacrifice in handling, and increased ride comfort. I agree it is hard to just compare treadwear numbers across brands, but 140 to 360 is no small difference non the less.
~Rob
Old Jul 8, 2005 | 12:59 AM
Finiti35's Avatar
Are you running them on stock wheels? What size did you get up front and how much are they?
Old Jul 8, 2005 | 01:05 AM
csdstudio's Avatar
Well considering the great (smell sarcasm) roads here, I went with the stock 18's and their respective tire sizes. I paid just over 650 shipped. I have to say I'm impressed with a tire that has not had the brand name recognition like many other tires. I'm more impressed that the car retains most of its handling capablilities and yet the ride quality has improved dramatically. With the addition that I will beable to drive it in a dusting of snow if needed. Not like it snows in MN anymore. But, now I have a set of 19's to deal with selling.
Old Jul 8, 2005 | 06:54 AM
neffster's Avatar
Exactly. Should be the SAME price...
Old Jul 8, 2005 | 09:23 AM
djinferno's Avatar
you go thru em quicker
Old Jul 8, 2005 | 09:36 AM
Infinite1's Avatar
20 Year Member
Originally Posted by whyjay91
Which BFG's? Sorry if there's only one that will fit ours. I came from knowing whether tires were mudders, AT's, swampers, bfg mud terrains, etc...so I'm new to the performance tire scene.
BFG KDW 2's....they're great for wet and dry traction...Go to tirerack.com so far i've found them on that site for relatively cheap...I like the OEM tires but they are pricey.
Old Jul 8, 2005 | 11:35 AM
MrCynical's Avatar
What perfect timing for a tire thread!
Just got my BFG KDW 2's installed yesterday. $1000 really isnt too unreasonable...these were under a grand but if I got the tires I really wanted (Pilot Sport 2's) it would have been 1400 or so. But let me tell you these BFG's look AWESOME on the car. Everyone that has seen them has already commented. The tread pattern rocks.
After driving a car with PS2's though I'll say if you have the means then GET THEM. They blow the original Pilot Sports out of the water.
I had all 4 done almost right at 20k. The fronts easily had another 5k in them, but the rears were totally gone. Past the wear bars, past the tread, they were perfectly smooth in the middle and almost across the whole tire.
Interested to see how the BFG's wear....
Old Jul 8, 2005 | 11:40 AM
Infinite1's Avatar
20 Year Member
Excellent...definitely keep us posted on the tread wear...$1000 isn't a bad price i was quoted $381 just for the rear tires which i plan to replace first...I still have tons of tread on the fronts
Old Jul 8, 2005 | 01:42 PM
cotmfk's Avatar
$381 per tire? Or $381 total for the rear?
Old Jul 8, 2005 | 01:45 PM
  #30
Infinite1's Avatar
20 Year Member
That was total for both rears...
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
