ignition amplifer?
ignition amplifer?
thinking about getting a igntion amp , but not sure which one. has anybody installed one, if so which one and is it worth it. also, will the stillen grounding kit still work with the amp?
If you're going to get a grounding kit, there is only one you should get. You should get it from a guy named Gordee. Make sure you get his 10-Wire Kit. I've put it on my 05' AT and it's great.
Stillen sells an ignition Amplifier for our cars. I don't know if anyone has installed this, if it makes youre car faster, or if it makes the engine run smoother. A grounding kit will make your car run better.
