My 04' 5AT Dyno!
My 04' 5AT Dyno! (UPDATED)
This is my 04 G35 5AT Dyno with the only mod being a AEM CAI (installed by Miller infiniti) I got this Dyno at the "Dyno Store" in Chatsworth today.7/19/05 . I noticed when I got home that they shut down at 6000 rpm dunno why. And I dunno how to know if my A/F is messed up because the computer read 14.6-7.
Temperature was 98 degrees 30 % humidity all 3rd gear pulls
SAE Corrected Numbers are:
Run 3 = 248.4 HP and 234.6 TQ
Run 2 = 244.6 HP and 234.6 TQ
Run 1 = 244.8 HP and 234.5 TQ
So this my baseline I'll post numbers after the Votech S/C get installed next week.
<img src="http://img.photobucket.com/albums/v240/illest350GT/Tillet04Infinity.jpg" alt="Image hosted by Photobucket.com">
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Good numbers but....
Do you know what other G35's are getting on that particular dyno? If they all get 240s with 5ATs, then it's reading higher than most dynojets. Which isn't a problem if you know that. Or do other 5ATs dyno 220s on that, which is what most 5ATs get stock on dynojets. If it's the latter, than you do have a strong car. If it's the former, than you just have a dyno that reads higher than most. Again, dynos are best for tuning, not comparing cars across the country.
Also, your max WHP is at 5800 RPM? And they shut it down before 6000 RPM?
Originally Posted by Rudeboy
This is my 04 G35 5AT Dyno with the only mod being a AEM CAI I got this Dyno at the "Dyno Store" in Chatsworth today.
248.4 HP and 234.6 TQ was the best of 3 pulls and the other 2 pulls got
Originally Posted by FLFIRE
Are the numbers SAE corrected or noncorrected?
Originally Posted by GPIMPIN
is it me or is he running a bit on the lean side??? I'm seeing like 15 to 1 or 14 to 1 and thats lean
I dunno why they shut it down at 6000 rpm though I do know I am the first G to jump on this Dyno however.
Originally Posted by KAHBOOM
WOW! It would be interesting to see what other G's got on this dyno as well. Do you have LSD?
Ya I would like to know also. But aren't there some Dyno numbers floating around here from a Dyno jet? No I don't Have and LSD as far as I know the G 5AT don't come with them.
Guest
Posts: n/a
Very nice. My highest HP on a DynoJet not corrected [if I remember right] on my 04.5 5AT Coupe was 230HP - from there I had 228, 228, 229, and an oddball 215HP. I also have the AEM CAI, and timing advanced 3* - I drive like a granny though...so depending on how the car is already mapped to perform maybe thats the cause?... Have you ever been to the track? I ran a 14.2 @ 97 [? kinda forgot].
