Dealer put in too much oil. what should I do?
Old Jul 28, 2005 | 12:15 PM
P_Diddy's Avatar
Question Dealer put in too much oil. what should I do?
I got an oil change at the dealer on Friday and I checked the oil level on Sunday. It was right above the "H", covering the whole letter plus a little more.
Would this create too much oil pressure or other problems? Should I try to get them to suck some oil out or just leave it?
If the cross-hatched area between L & H is 1 qt (not sure if this is true), then it looks like they added 1/4 quart too much.
Old Jul 28, 2005 | 12:48 PM
madchef's Avatar
You should be ok, doesn't sound like there's so much that it would cause a problem.
Old Jul 28, 2005 | 01:09 PM
SilverII's Avatar
You should be fine....
Old Jul 28, 2005 | 01:20 PM
Finiti35's Avatar
FGC South Florida BOD
I would also like to know if this is true. I can't read a dipstick for the world.
Old Jul 28, 2005 | 01:26 PM
IS300TOG35's Avatar
► Matt ◄
I'll teach ya
Old Jul 28, 2005 | 01:28 PM
Finiti35's Avatar
Hahaha.. so the answer is???
Old Jul 28, 2005 | 01:30 PM
Msedanman's Avatar
O.F. Administrator
You should be fine bro.....My rides usually come with a half quart too much from the factory with no issues.
Don't worry about it, but it's good to check in case it's too low.
C.
Old Jul 28, 2005 | 01:53 PM
FAST1's Avatar
Putting too much oil in your engine could cause the oil to foam. In other words if you have too much oil, the crankshaft could come in contact with the oil causing it to foam which will affect the lubricating properties of the oil. I would estimate that you would need at least a quart too much of oil to cause this condition, so you should be fine.
Old Jul 28, 2005 | 02:24 PM
KAHBOOM's Avatar
What FAST1 said ^^^
Old Jul 28, 2005 | 02:48 PM
P_Diddy's Avatar
Thanks for the replies. We could definitively close this topic if Q45Tech would pop his head in here. Anyone have access to the bat, i mean Q45, signal?
brownie
Nov 25, 2015 12:50 AM
RA081024
Aug 18, 2015 07:03 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
mostestG35
13
Aug 15, 2015 05:56 PM
Jadenkid22
Jul 14, 2015 12:33 AM
