Tracking the G tomorrow on 1.8mile roadcourse in Louisiana, advice?
Old Jul 29, 2005 | 08:05 AM
Balzz's Avatar
Alright, lemme get right on that 993 track car.
Old Jul 29, 2005 | 09:11 AM
ScapGF's Avatar
Thanks for the continued advice!
I'll be sure to post my experience and some pics. I'll also let you guys know how the brembos with stock pads and fluids hold up.
This time I only had 2 days notice, so next time I will get some track pads and better fluid. Then I can really note the difference.
And yes, you are correct about the possibility of damage even in the runoff areas. Luckily since this is only a 1.8m circuit the speeds don't get quite up there as much as they would on a 2.5-3.0. Track setup is basically one 1900' straight ending with a chicane, then some small essess, a 1000' straight, a couple more meandering turns, 800' straight, then long right hander going to start/finish.
I can't wait! I literally couldn't sleep last night, like a 7 year old on Christmas Eve!
Old Jul 29, 2005 | 08:18 PM
636Racer's Avatar
i've ran the street tires at 30psi on track days. I'm still sitting here at my computer writing. 30psi is NOT dangerously low psi. as heat progresses in the tires, the psi goes up a few psi...so really, at track temp you're getting anywhere between 35psi-40psi. i've found that at 30psi worked for me, i'm not implying it will work for anyone else. bringing the psi down contributed o giving me an average of .50 seconds off my lap times...but, that at my neck of the woods.
i'm not trying to kill anyone. all i'm suggesting is to try it out. if you dont like it, dont do it or bring the psi back up to 35-40psi, wherever you have it. if youre a consistant driver, playing with tire pressures will account for some time if you have nothing else to adjust, you just have to play it by ear.
http://www.superlapseries.com/results.htm
between the results of the months of may 7th and july 24th, my lap times have been dropping. between may and june is where i started to play with the tires pressure. during the last event, i would've had a better final lap time if i hadnt screwed up in few parts of the course, while on DOT R Compound tires. I havent had the chance to play with the pressure, but I will next time, in hopes of setting another personal best. My number is 57R
Old Jul 29, 2005 | 08:26 PM
636Racer's Avatar
Originally Posted by ScapGF
Also, it appears that most think they stock brake pads and fluid are very lacking.
Any recommendations on aftermarket? Cost?
hawk blue pads and ATE superblue brake fluid
Old Jul 29, 2005 | 10:37 PM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
LIKE 636Racer says, 30 Psi works, keeps the G from pushing so much, especially if you have the stock sway bars & or springs...
Important:
DO NOT PUT YOUR EMERGENCY BRAKE ON AFTER SEVERAL HOT LAPS, DOING SO COULD WARP THE REAR ROTOR.
ALSO LET THE CAR SIT WITH THE HOOD UP AND IDLE FOR SEVERAL MINUTES AFTER COMING IN TO LET THE FANS BRING THE ENGINE TEMP DOWN...
********EXTERIOR-MODS********
Carbon Fiber C-Pillars, Rebadged SKYLINE/NISMO Emblems, Blacked-Out Lower Rear Exhaust Fascia, Carbon-Fiber Rear View Mirror Bases, JDM Clear Corners w/PIAA LED's, PIAA Clearance Bulbs, Brushed Alum.Finished Front Grill, ANTI-PHOTO & LASER Tag, JDM Battery Cover, Polished Cam Covers, Carbon-Fiber Finished MAF...
********INTERIOR-MODS********
FIVE-SEAT CONVERSION w/ Lap Belts & Interchangable Pad or Rear Seat Console, Hide-Away PASSPORT (G-Timer), 2004 Front Console w/Arm Rest & Drink Holder Illumination, 35% Window Tint, NISSAN Drilled Pedals, NISMO Clock Mod, NISMO Horn Button, NISMO Rear Seatbelt Pads, SKYLINE Door Sills, Skyline Trunk Mat, Remote Window-Up Mod, VDC Memory Mod, PAC AAI-NIS i-Pod Audio Interface...
Attached Thumbnails Tracking the G tomorrow on 1.8mile roadcourse in Louisiana, advice?-g35tracktightturn.jpg   Tracking the G tomorrow on 1.8mile roadcourse in Louisiana, advice?-drift1mediumlarge.jpg
Old Jul 29, 2005 | 11:01 PM
636Racer's Avatar
Thumbs up
Or you could do some cool down laps.
Old Jul 30, 2005 | 06:58 AM
Balzz's Avatar
RugRat, are those 20" wheels you're tracking on?
Old Jul 30, 2005 | 07:12 AM
dentalstud's Avatar
20 Year Member
19" LMGT4's. They don't make those in 20". Hey, I don't guess you're ready to "upgrade" your wheels Rugrat, and sell me your Nismos, huh?
suby01
Not G35 Related
May 25, 2016 03:07 PM
AJC128
Nov 1, 2015 11:55 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
