Driving stick, some quick questions about it...
Old Aug 3, 2005 | 06:34 PM
gto2050's Avatar
Originally Posted by VakhariaINC
Don't you post on OT?
This is "TechArt" :mamoru:
You too?
Balzz's Avatar
Originally Posted by gto2050
You too?
:fawk:
Old Aug 3, 2005 | 06:35 PM
gto2050's Avatar
Originally Posted by Balzz
:fawk:
I know...we need more smilies!!!
Old Aug 3, 2005 | 06:45 PM
Atooraya's Avatar
Originally Posted by Finiti35
It's your gears spinning to a stop. Shut the car off in gear with the clutch in and you won't hear it. If it doesn't want to let you put it in gear say from neutral, make sure you've revmatched correctly.
i leave it in neutral with the ebrake on when it's in my garage
should i always leave it in first?
my friend left his gti in second
Old Aug 3, 2005 | 06:47 PM
VakhariaINC's Avatar
We should try to see if we can get a discount if us OT members purchase 2 vehicles together at the same time, that would be great. I'm definetly looking for a new ride...
Old Aug 3, 2005 | 06:51 PM
Atooraya's Avatar
u gays all have g35c's? :buttsex:
Old Aug 3, 2005 | 06:56 PM
Balzz's Avatar
:hahano:
Old Aug 3, 2005 | 07:12 PM
FAST1's Avatar
If you are on an incline, an added level of safety is to leave your car in first gear. As for the smell of a burnt clutch, I haven't experienced that yet, but I know how to get it. What you do is to depress the clutch pedal, rev your engine to 4-5K rpm, and then let the clutch pop. This is also a great way to test a clutch for wear if you buy a used car. When I test drove used Porsches, I would always try this test. I can't say that any salesmen liked my test method however.
Old Aug 3, 2005 | 09:48 PM
S2020's Avatar
Car smells horrible for the first couple hundred miles. Only way to get rid of it is to redline constantly.
I hope everyone knows he's joking
Old Aug 3, 2005 | 10:11 PM
g35_anonymous's Avatar
Ok great
also, when i shutdown the car, i'll hear some clanking noise. I read that this may be the clutch chatter which is normal, but i was also thinking that it may be the timing belt? The dealer told me that the g35 has a chain as a timing belt, and when i heard it, i thought maybe it was just the belt?
This is a known problem on the 04' and 05' models. I had the same problem and when I took it to the dealership they told me that I had the first 05' they have seen with that problem but it was common on the 04's and they knew exactly how to fix it and did! take it to dealership if you hear any clanking while throttling in low gears or when shutting the car off.
Th611
Oct 27, 2015 03:48 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
