Deven Infinity for problem fix.
Old Aug 6, 2005 | 11:34 AM
05GCOUPE6MT's Avatar
Devan Infiniti for problem fix.
Called Up Devan Infiniti to have my rear axle looked at and radio (rear axle noise) and (radio re-sets itself). They new what both problems were and would fix it. I will be dropping off the car on Friday 08/12. I was going to mention the clutch noise, but most say it is a caracteristic of the G. Anyway the noise seems to lessen every $1K mi. or so. I just hope they replace the Axle not just lub them up.
I will keep you all updated.
Old Aug 22, 2005 | 03:57 PM
Well, I called up devan and thay said they lubed & tightend the rear axles. The radio problem is not fixed yet. They said It may be a ground problem or a defective head uniti. They said they would call me tomorrow.
Old Aug 22, 2005 | 04:08 PM
Armani350GT's Avatar
The Head Unit is definitely a defect. I also want to fix it but don't want to do that unless I know that the new radio that will be installed is defect-free. Keep me updated on this one.
Old Aug 23, 2005 | 06:12 PM
They could hear any problems with my car. They said they compared it to another coupe and it sounded the same?.
Old Aug 23, 2005 | 06:18 PM
I told Devan that by lubing the rear axle will just be a teparary fix. They called me back the next day and said they placed an order for the parts and should get them in about 2 weeks. I will have to bring the car back at that time. I think they ordered new bearings, Bolts, pins, and boots. I will keep you guys updated.
Old Aug 23, 2005 | 08:29 PM
gettaluvr's Avatar
dont worry about the radio, i think all 05 does that reset it self after you turn off the are and left +5for both bass and treble, i've has it replace with a new one from japan and it still does that same
Old Feb 11, 2006 | 10:14 PM
The ticking noise came back on 12/05 ( after the lube 08/05 ). I got tired of hearing it, so i called the dealer back on 02/06. They told me the parts are not on back order and would have then in 2 days. I just had the car fixed and they replaced rear axe bolts, carter, & lube. The ticking noise is gone & I am hoping it stays this way.
wonderizm
Sep 24, 2015 03:09 AM
G35fromPA
Interior
21
Sep 20, 2015 08:58 AM
derres
Aug 28, 2015 03:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
chinee
Aug 8, 2015 10:11 AM
