Resistance putting gear shifter in gear...
Old Aug 7, 2005 | 10:33 PM
Atooraya's Avatar
i was driving today and i went to shift to 3rd and noticed there was some resistance. I know it wasnt grinding at all, but i had to push a little harder for some reason
Old Aug 7, 2005 | 10:43 PM
ZeroGen's Avatar
Omega Enthusiast
Clutch depressed?
Old Aug 8, 2005 | 12:03 AM
gettaluvr's Avatar
i have the same problem but only when i push my car, higher rpm it's harder to get the gear in
Old Aug 8, 2005 | 02:11 AM
Atooraya's Avatar
Originally Posted by ZeroGen
Clutch depressed?
well it's not grinding
Old Aug 8, 2005 | 05:47 PM
rase-r's Avatar
Mine does the same thing, it's been discussed in a few other posts earlier this year.
And for the "Clutch depressed" comment... I can shift gears without a clutch, it's not that hard. I used to drive gravel trucks, after shifting 1000's of times in a day your leg gets really tired. You learn real quick how to shift without a clutch.
Old Aug 8, 2005 | 07:08 PM
Atooraya's Avatar
that's not good for your tranny at all
Old Aug 8, 2005 | 07:39 PM
SkylineR35's Avatar
If you do it right it isnt THAT bad... I'd like to know how though. Got some tips?!
Old Aug 9, 2005 | 12:45 AM
Finiti35's Avatar
FGC South Florida BOD
Yup when you try to shift fast it happens every once in a while. Don't worry your car is nothing out of the ordinary.
Old Aug 15, 2005 | 08:47 PM
rase-r's Avatar
Sorry I've been gone for awhile. Before I give out any tips on how to do this I want to say that I learned on old beater trucks and cars. So don't go trying this on your G35.
First off this is not power shifting, it's shifting without using a clutch. To get it out of gear hold your RPM's steady around 3-4K with no load, then gently slip it out of gear, give your gas pedal a little blip to rev match to your speed, then slip it into the next higher gear. If you get your RPM's right, it slips into gear without any problems.
I used this to get my se-r home once when the clutch cable broke, I got lucky and hit all the lights green, sliped it out of gear and coasted into the garage.
brownie
Nov 25, 2015 12:50 AM
Th611
Oct 27, 2015 03:48 PM
Frostbite91
Aug 20, 2015 07:20 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
Jadenkid22
Jul 14, 2015 12:33 AM
