plenum spacer help!
Old Aug 14, 2005 | 09:04 PM
gixxer2k4's Avatar
Unhappy plenum spacer help!
I have been emailing motordyne for the past 3 weeks and i never get a reply. I have a 2005 coupe and im interested in getting a spacer, but i still dont understand what this thermal spacer is all about can someone please clarify it for me? also does anyone know if theres any torque loss with the spacer? and is out yet? if not when should it be released? should i buy the 3/8 spacer or this thermal 5/16? please help! thanks in advance
Old Aug 15, 2005 | 01:46 PM
DannoG35's Avatar
I haven't heard of the 5/16 thermal spacer. I do have a 3/8 MD plenum spacer. I like it. I felt an instant difference in power. I am not sure about torque. All I knwo is that there is more power all they way throught the whole RPM band.
Old Aug 15, 2005 | 02:23 PM
glennp_1999's Avatar
Look at this thread...might help you out.
https://g35driver.com/forums/g35-coupe-v35-2003-07/63784-crawford-cast-plenum-vs-motordyne-spacer.html
Old Aug 15, 2005 | 02:31 PM
cjac69's Avatar
I've also emailed twice since last Thurs, no response. Why is there not a phone
number on teh website? Seems very strange to me...
Old Aug 15, 2005 | 03:33 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
The plenum spacer and the thermal isolator are 2 separate items.
From what I understand they will be sold as a kit (2 parts)
The difference in the two is:
- The plenum spacer goes between the two halves of the plenum to give more volume.
- The thermal isolator goes under the lower plenum, on the lower intake runners.
The purpose is to help the air plenum to run cooler.
Old Aug 15, 2005 | 04:48 PM
EricIsKlumzyee's Avatar
Theres more to the thermal kit then that.. but basically it allows air to come in MUCH cooler.. greater then what any form of cold air can do
Old Aug 15, 2005 | 09:42 PM
InTgr8r's Avatar
Yes probably, but not much more.
Here's a pic from "The Mole"
Old Aug 15, 2005 | 10:56 PM
wnt1bd's Avatar
I have the Thermal Kit. It comes with the new gasket that goes under the lower portion of the Plenum. It also comes with a valve to turn off the coolant to your throttle body during months that it is above 55 degrees. There are new plastic/poly spacers for the bolts in the center that actually clip on to the bolts and will not squish if slightly over torqued. I have not yet installed these parts as of yet, because my car is in the shop now getting the clicking from the rear right axle. I email Tony quite a bit and he answers rather quickly. I would try again.
Old Aug 16, 2005 | 12:47 AM
Hydrazine's Avatar
I'm sorry about that! I try to get to all the emails but I get so many sometimes its hard to keep up.. And I have been up to my neck in new development work and many sucessfull dynos! I wish I could talk about them but I can't just yet.
As for torque, if Pre/Post dynoed accurately, it will never show a loss.
Old Aug 16, 2005 | 03:04 AM
CarFanatic56's Avatar
is there also a noticeable sound difference with the addition of a spacer since more air is rushing in and not restricted?....how bout with the 5/16th spacer? thanks
Old Aug 16, 2005 | 03:25 AM
it makes the engine sound alot meaner.. so yeah your engine is now lounder at full throttle
Old Aug 16, 2005 | 11:43 AM
gixxer2k4's Avatar
thanks everyone for your help, tony finally got back to me the other day
Old Aug 16, 2005 | 09:55 PM
DannoG35's Avatar
I new Tony wouldn't leave you hangin. Glad you got some answers.
Old Aug 17, 2005 | 07:59 AM
InTgr8r's Avatar
Interesting!
Is it a manual valve?
Or, a solonoid valve with thermostat control?
Old Aug 19, 2005 | 05:12 AM
richie's Avatar
has anyone tried the Skunk2 spacer???
or does anyone know about installing the 350Z Lower Intake Plenum Manifold?
http://performancenissanparts.com/ca...oducts_id=3328
suppose to have good results?
