Tranny flush killed my exhaust sound :(
Old Aug 24, 2005 | 06:55 AM
FAST1's Avatar
Originally Posted by dwoloz
30k on my G and I decided it was time for a tranny flush
After the flush it feels really good; shifts are smoother
Weird thing is though my sweet exhaust note is now greatly diminished. Sure I still get it if I rev high but its not as good as before
Ive noticed this with new Gs that they have a more subdued exhaust sound.
Any explanations?
Take a second and think about what causes your exhaust to make the sound it does. It's simply the sound of air passing down a tube. The only factors that will affect the sound will be the speed of the air passing down the tube, the length, the shape, and mufflers in the tube. Flushing your tranny will have about the same affect on your exhaust sound, as will washing your car.
Old Aug 24, 2005 | 09:05 AM
reboot04's Avatar
I agree....if you wash your car now you should get the exhaust sound back and be flossin'.
Old Aug 24, 2005 | 09:10 AM
sofl_g's Avatar
Originally Posted by KAHBOOM
The only other consideration is that with the tranny flush there is less load / resistance from gunk in the tranny and now the engine is not working as hard.
Having worked a few years in a High Performance Auto trans shop, if you have "gunk" in your trans after 30K miles, there is a problem with the design of that unit. Imagine after 60 or 100K? Our "crappy domestic" SUV has 177K on the original Auto and it is still chugging along.
Old Aug 24, 2005 | 10:15 AM
gbest03's Avatar
Is it possible that the flush changed the shift points?
Try disconnecting your battery over night, it will reset the ecu and the shift points will relearn themselves.
In other words, it might be shifting at lower rpm's.
Old Aug 24, 2005 | 12:23 PM
GeeMan's Avatar
What was the cost of the tranny flush??
Old Aug 24, 2005 | 12:33 PM
Sumlime311's Avatar
Yes that is very strange I did the trany flush and i thought it sounded the same after. Just the gears were changing smother.
Old Aug 24, 2005 | 12:34 PM
dwoloz's Avatar
This sounds plausible
I just reset my ECU; Ill test it out later today
Tranny flush cost $125 which isnt bad considering the damn fluid costs 10 bucks a quart
Old Aug 24, 2005 | 12:42 PM
GRider35c's Avatar
im going fully synthetic in my tranny and diff today, ill see what happens to the exhaust note and let u know!
wouldnt that be cool if it got louder!!
Old Aug 25, 2005 | 07:38 PM
yofool's Avatar
YoFool. They are not related at all. It is in your brain man.
Old Aug 25, 2005 | 08:05 PM
jcboizi's Avatar
Any explanations?
How much did this cost you by the way???
Old Aug 25, 2005 | 10:48 PM
Msedanman's Avatar
O.F. Administrator
haha, great thread guys....
to me , the only way this happens is if the dealer fixed a leaky exhaust pipe while doing the tranny maintenance.
The mechanic probably found a loose flange bolt and tightened it (because he is an observant mechanic). There still are people around that care and go 'above and beyond'.
My .02
C.
Old Aug 25, 2005 | 10:54 PM
Pwoz's Avatar
This thread makes me laugh haha
Old Aug 26, 2005 | 08:22 AM
Balzz's Avatar
This thread is truly stunning.
Old Aug 26, 2005 | 08:25 AM
Section8's Avatar
You guys, Nissan does a complimentary muffler bearing replacement and repack when they do transmission fluid flushing, that's why his exhaust sounds quieter. If'd you had them change your blinker fluid then your turn signals would be quieter too.
Old Aug 26, 2005 | 08:28 AM
  #30
Balzz's Avatar
I installed cross-drilled brakelines and my brake pedal is nice and easy to press now. Hardly takes any effort at all.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
Daniel k.
Nov 3, 2015 09:52 AM
discoswan
Engine - Exhaust
Oct 16, 2015 10:42 AM
underworld
Aug 6, 2015 01:36 PM
