Shifting
Old Sep 1, 2005 | 03:07 PM
kenchan's Avatar
i do 1-3 after backing out of my driveway while the tranny is cold because 1-2 is a tad notchy, but other then that, i use all the gears.
i haven't really paid attention to the shiftpoint speeds, but i usually shift up
before 3.5k for normal accleration.
htownboy's Avatar
Originally Posted by Hotrod
The flywheel has nothing to do with it when the car is in Netural or when you have the clutch depressed. With the car in neutral and the clutch out the engine is not directly connected to output shaft of the trans. With the clutch depressed but in gear the flywheel is not connected to the trans via the pressure plate, and with the trans in neutral and the clutch in both the clutch and the gears in the trans are not engaged to the flywheel. In any event the flywheel will make no differnece. If you don't believe me go 30 miles an hour and put your car in neutral and let it roll. then do the same thing but also turn the engine off. There will be no difference since the flywheel in not directly connected to the output shaft in either case. The only effect a heavy flywheel has is when you launch hard and you get the extra energy stored in the added weight of the spining flywheel.
Amen!
Old Sep 1, 2005 | 04:00 PM
Dave E H's Avatar
The reason they suggest these shift point is to make their MPG #'s. If you drove it that way all the time, you'd be close to what they quote on the sticker.
Old Sep 1, 2005 | 04:25 PM
Pwoz's Avatar
Yeah..hmm that was something I was always told (what I posted) so I never really thought about it... but thinking about it it now seems really stupid. Doh, I should just not believe people all the time instead of most of the time
Old Sep 1, 2005 | 05:33 PM
TheGest's Avatar
Gangster Member
drive the car and enjoy how you want it, if youre driving this car and shifting at points to save gas, your in the wrong car, time to sell and get a civic
Old Sep 1, 2005 | 06:43 PM
htownboy's Avatar
Why just waste the gas during your commute to work wherever you are in traffic??? Of course when the weather is cool enought to ride with the roof open & windows down I do like to shift higher than 3000RPM's, just to hear the exhaust sound, but the mileage does suffer some.
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
