injen intake. safe to order? (searched)
Old Sep 10, 2005 | 09:36 PM
Hooman6MT's Avatar
20 Year Member
Originally Posted by Jtrain
lol-- I don't want to remove anything =(
you will have to take off at least the inner wheel fender. You're also going to have to take your existing intake out, and that takes time and effort too. No one said modding was going to be easy
Hooman
Old Sep 11, 2005 | 01:11 AM
Triple8Sol's Avatar
Originally Posted by eyazdchi
thing is that there is an induction problem ... the loss of pressure when the clutch is engaged doesnt allow enough air to flow through the MAF ... its like "no air?", and therefore it shuts down the engine cuz it thinks something is completely wrong ... now the heatshield keeps the turbulent air from causing an induction problem for that second it takes to shift, thereby relieving the issue ...
I'm reading your post over and over, but I really don't understand your logic. How would the heat shield do anything to create a steady, constant stream of air VS. any turbulent air that might normally be present? From looking at the posted pics (thanks for those btw) seems like all it does is preventing the filter from sucking in as much air as possible...
Old Sep 11, 2005 | 01:28 AM
Og_Dave's Avatar
i got the Nismo intake.....been happy with it and sounds soo mean =] but its all what you like
Old Sep 11, 2005 | 01:55 AM
borahatch's Avatar
From what I've been told and from my own testing... I think what is happening is, as you go past 60 and take the load off the engine, too much turbulent air is getting through the filter into the intake pipping and causing the MAF to go crazy... This wont happen if the car is in gear or if you're giving it some gas (even to speeds beyond 60) because the car is sucking in the air so it is less turbulent. All the heatshield does is prevent the filter from getting hit directly from the outside air. Less turbulence = no stalling.
Old Sep 11, 2005 | 09:19 AM
JDM 350GT's Avatar
i talked with one of sponsors here and the guy told me if you can jack up your car, you can install w/o removing any parts.
Old Sep 11, 2005 | 09:28 AM
ranks44's Avatar
I have had no problems with my injen CAI and it sounds sick! I installed it in my driveway - no jack and did not take off the bumper. Just open the wheel flap and you can install perfectly!! I also bought it from a company on this site for $240 shipped
mikemf8
Forced Induction
Sep 4, 2015 12:11 AM
mikemf8
Sep 3, 2015 08:01 PM
UT G35
Sep 3, 2015 03:58 PM
