tire pressure senor problem
Old Sep 10, 2005 | 11:17 PM
gettaluvr's Avatar
i swapped my rims two front rims+tires with my friend, we both have tire pressure sensor both are 05. do i need to go back to dealer to have them reset and let my ecu learn his TPS for it to work ?
or i can just leave it?
it's been few days so far my TPS hasnt went off.
and i tried today to set my front tire to 28psi, took a quick spin(1 min or so) in parking lot my tire pressure sensor didnt go off. but when i set my rear to 29psi it went off right away. and i pump rear back to 35psi warning goes away
if my ecu doesnt know the new TPS shouldnt the light comes on with no buzz sound like how people change to aftermarket rims with no TPS?
if it does how come when i set the one i swapped with my friend to 28psi the TPS didnt go off ?
Old Sep 11, 2005 | 12:01 AM
gettaluvr's Avatar
anyone ??
Old Sep 11, 2005 | 02:15 AM
Strider_GTS's Avatar
Ironic...
I was just going to come in here and post my little tire sensor problem and noticed there was another thread about our tire pressure sensor so I figured I might as well post here hehe.
Just a few days ago my tire pressure sensor buzzer and light went off but none of the tires went flat so I has the tire pressure checked and they were all exactly the same and perfectly fine as far as the pressure goes. About a day later the light went off for about another day and then just yesterday the buzzer went off and light came on again and sense then it hasn't gone off (however I have heard that freaking buzzer about 4 times for no real reason). I'll assume this is just a problem with my sensor until anyone tells me otherwise? Is that my problem or has anyone else had similar problems? How do I fix this? Just take it to the Infinity dealer? That's kind of a pain because the closest infinity dealer is about 3 hours away... Freaking Oregon...
Old Sep 11, 2005 | 04:08 AM
andychan's Avatar
Just a few days ago my tire pressure sensor buzzer and light went off but none of the tires went flat so I has the tire pressure checked and they were all exactly the same and perfectly fine as far as the pressure goes. About a day later the light went off for about another day and then just yesterday the buzzer went off and light came on again and sense then it hasn't gone off (however I have heard that freaking buzzer about 4 times for no real reason). I'll assume this is just a problem with my sensor until anyone tells me otherwise? Is that my problem or has anyone else had similar problems? How do I fix this? Just take it to the Infinity dealer? That's kind of a pain because the closest infinity dealer is about 3 hours away... Freaking Oregon...[/QUOTE]
Are you sure you don't have a small leak in one or more of your tires? Check for nails. You probably will need to raise the car up to examine the tires completely.
Old Sep 11, 2005 | 04:17 AM
That's what I would assume naturally but I had all 4 tires checked out and they were all exactly the same and a perfectly fine psi.
/shrug
Old Sep 11, 2005 | 04:54 AM
andychan's Avatar
/shrug
Did you dunk the tires in water to check for leaks? Maybe your sensors are bad. I'm thinking one of your tires has a leak.
Old Sep 11, 2005 | 10:05 AM
gettaluvr's Avatar
well anyone can answer my question??
Old Sep 11, 2005 | 10:09 AM
dave's Avatar
If you want the new TPS sensors to work on your car, you have to take it to the dealer. They will register the new TPS sensors with your car.
Did you check all of the pressures when the tires are cold? The temperature of the tires can change the tire pressure by several pounds.
If you did check the pressure when the tires are cold, it sounds like time for a trip to the dealer. They should be able to recalibrate the sensors.
Old Sep 11, 2005 | 12:00 PM
Meth68's Avatar
I agree with dave, I was having the same issue and it turned out to be a temp issue more then anything. One morning my tire pressure sensor went off, I checked my tires and they all seemed high so i set them back to the 35psi listed on the door sticker and the light went out. The next morning it was cold again and my sensor went off again i checked the pressure before the tires were hot and they were all low now. I set them all back to 35 and now its been fine for a week or so. I hope this isnt a common problem :/
Old Sep 11, 2005 | 12:24 PM
Yea I guess it has been getting a lot colder lately.
I'm just pretty darn sure my tires aren't leaking. If one of my tires was leaking it would be low by now. You can't have a tire leaking for a week and still have every single tire be at the same PSI.
I think the only thing I can do is take it to the dealer and have them fix the sensors. It's looking like I'm not the only one who has had problems with their sensors. Uggg, I just wish Nissan could do the fix so I wouldn't have to drive 200 miles to the closest Infiniti dealer.
Old Sep 11, 2005 | 12:33 PM
GEE35FX's Avatar
This is my experience with the Tps monitors, I purchased 4 tires and rims from a friend from his 05 Sedan and they work fine on mine without getting them reset at the dealers. I kept his sensors.
The weather turned cooler here and my sensor light came on. The next morning after tha car sat all night I checked the tire pressure and it had dropped enough with the cooler weather to trigger the sensor light. I increased the pressure and it has been fine ever since.
As another note, make sure your tire pressure gauge is accurate.
Old Sep 11, 2005 | 03:31 PM
chicagokid's Avatar
To be on the safe side... it's a good thing anyway to check tire pressure once a month. Can't go wrong there.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
joedaddy1
Jul 28, 2015 02:58 PM
