Question about window.....kinda dumb
Old Jul 11, 2003 | 12:45 AM
Type_R_Boy_251's Avatar
This is a very very stupid question, but here it goes anyways.
On the coupes as you all know the window goes down slightly when you open it. I know that this is done to form a better seal. BUT what happens if your battery dies? is there enough room for the window to clear in order to open the door?
Old Jul 11, 2003 | 01:08 AM
Sloneek's Avatar
Re: Question about window.....kinda dumb
no if the battery dies and ur in the car ur screwed SCREWED
Quick Robin... TO THE BATMOBILE.
Old Jul 11, 2003 | 02:45 AM
Banatoman's Avatar
Help... I am running out of air in here... my battery died!
Banatoman
Old Jul 11, 2003 | 06:53 AM
Msedanman's Avatar
O.F. Administrator
LOL, You're safe bro. The door will open, just like it does when you normally open the door with battery power. From what I've seen on my Coupe, the window hardly has time to lower b4 the glass clears the window frame, so I would say the slight lowering is to facilitate closing the door rather than opening it.
Due to the curve of the pane, it would catch on the frame on closing the door and possibly break the glass or damage the frame. Thus the 1/4" drop.
<font color=green>GSM</font color=green>
Old Jul 11, 2003 | 12:42 PM
masetodd's Avatar
Yes - the last poster is correct. You can get OPEN the door if the battery dies, but you do not want to CLOSE the door unless the window has been lowered.
G35 6MT/DG/Fully Loaded
Old Jul 11, 2003 | 01:09 PM
Cali_Eddie's Avatar
you can even try it out for yourself... I did and it worked... open passenger door as a just in case... and pop the hood and disconnect the battery.. then try to open the door..
G35 Mafia Member # 01
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
