Burnout with an auto?
Old Sep 26, 2005 | 06:37 PM
P_Diddy's Avatar
One more note, I don't think it is possible to do a standing burnout in an auto, where you are spinning the tires in place. This is because the ECU will limit the throttle while the brake pedal is depressed.
Old Sep 26, 2005 | 06:41 PM
Jtrain's Avatar
So besides minor tranny wear, and major tire wear-- brake torquing wont really mess anything up to bad?-- My tires are bald man, And i've always said I've wanted to do burnouts before I got new tires.
Old Sep 26, 2005 | 07:35 PM
Sumlime311's Avatar
Well someone needs to take a vid and post it. PLEASE
Old Sep 26, 2005 | 08:32 PM
s14roller's Avatar
Neutral dropping will produce the most smoke period...you'll see smoke pouring from everywhere...engine, tranny...
Old Sep 27, 2005 | 12:49 AM
VQpower's Avatar
Originally Posted by PeteNJ
Most auto users put the transmission into "N" and rev it until you are bouncing off the rev limiter. Then they go ahead and drop into "D". Plenty of smoke
PS: Please have a video camera on hand to record this when you give it a shot.
please tell me that you havnt done that yet. that will make your tranny go bye bye. all you have to do is power brake it with the vdc off...it has enough power to break the tires loose.
Old Sep 27, 2005 | 08:43 AM
madabs's Avatar
If you put bleach on your tires it helps produce more smoke.
Old Sep 27, 2005 | 10:23 AM
PeteNJ's Avatar
Yeah I do it all the time with my slushbox equipped G.
Old Sep 27, 2005 | 11:25 AM
S-Tuned's Avatar
gtr proto test driver
Originally Posted by Hotrod
priceless
ahahah..
Ok really.. Hold your brake down, Step on gas give it like 4-5xRPMs (2-3x gives you a nice launch) and let go of brake and floor the gas see what happends../ with VDC off, and be carefull car will slip a little
Old Sep 27, 2005 | 09:54 PM
636Racer's Avatar
is it even possible to do a standing burnout without the use of a linelock?
I tried side stepping (heel/toe) and dumping the the clutch with the VDC off, and cant get a decent standing burnout. Looked at the oneline diagrams of the service manual, the throttle, abs, and vdc are linked. so engaging the brakes would cut the throttle as if ecm was thinking the car was losing traction on the drive, all the while knowing the VDC isnt fully disengaged.
Old Sep 28, 2005 | 01:31 AM
trelokomio's Avatar
ahh bringing back memories of that burnout boy with the AWD G Sedan who came onto the coupe forum and wanted to peel out (dumb*ss)
Step 1 step on your brakes
Step 2 rev to 3000 rpms
Step 3 let go of your brakes
Step 4 Immediately after step three floor it
You know what else is fun and you should videotape, turn off your VDC, turn the wheel and repeat steps 1-4 plus hold it for 8 seconds
Old Sep 28, 2005 | 09:30 AM
almansouri's Avatar
Shove an IMPUL control unit in your G **** it will give you sugar
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
