Every G35 'KP Technologies' Module unmasked and reviewed!!
#31
on
Originally Posted by ChuckP
how much is the shift light going to cost when finished? Can you select any rpm for it to blink at?
As for price, you should contact Kevin (KPierson).
But I will answer the other question. Yes, you can set it to blink at whatever RPM you like. It's VERY easy to set as you just hold the VCD button for a few seconds until the light turns on solid and then let go. You then rev the needle to half of where you want the limit set (example...Mine blinks at 5000rpms...so....to set it there, I simply push and hold the VDC button and rev my car (easy to hold whatever rpm you want while actualy driving) to 2500 rpm and hit the VDC button again. Presto...set.
This method makes it very easy to change or modify the setting whenever you want. Helpful for the differences in everyday driving and track driving.
#33
#37
#40
#42
on
KPTechnologies group buy
**************KPTechnologies Group Buy.**************
From NOW until the end of MAY.
What the products are all about:
I have set up a group buy with KPTech for discounts on their window up and sunroof control modules. These modules let you open and close your windows and sunroof with your key fob. For the official thread follow this link.
https://g35driver.com/forums/nationalgclub/98195-kptechnologies-group-buy.html
Tolboothwilley™
Exterior-Vendor
07-28-2016 12:42 AM
bTanz
10-15-2015 02:31 PM
laksjd84
07-24-2015 05:12 PM
