Help I Need G35 Coupe Engineer Drawings
Old Oct 18, 2005 | 02:50 PM
DannoG35's Avatar
Hey guys I need some help getting some accurate drawings of the G35. I am looking to import this into Autocad and use it as an accurate base. If you can help please reply or PM me. Most specifically I am looking to get an engineering image of the front of the car and the grill including mounting points. I have done a pretty extensive search and have not found any images yet. Thanks
Dan
Old Oct 18, 2005 | 03:09 PM
giddyup69's Avatar
your gonna use autocad to view vehicle dwg's? your crazy... use catia or something more suitable.
Old Oct 18, 2005 | 03:20 PM
DannoG35's Avatar
Don't know those programs and I am not viewing I am importing them to modify. I need specific drawings that I can work from to prototype parts. I am wondering if it is possible to get them from Infiniti. Maybe those other programs are better and I will look into them but I am educated on autocad so thats what I will most likely be working from.
Old Oct 18, 2005 | 03:26 PM
GHBG35's Avatar
Good Luck with that
I don't know if this helps...
http://blueprints.onnovanbraam.com/m...ew.php?nr=5127
Old Oct 18, 2005 | 04:04 PM
P_Diddy's Avatar
Drawings and CAD models are proprietary and they're not going to be available. Your best bet is to take some parts to your local CMM shop (coordinate measuring machine) to get accurate dimensions. You will not know tolerances of these parts though since you are only measuring one example.
Old Oct 20, 2005 | 01:39 PM
DannoG35's Avatar
Originally Posted by GHBG35
This does help a little I might be able to zoom in on the front little more. Not sure if these are accurate. I need a close up of the grill.
vmcarbuyer
Oct 12, 2019 12:42 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
igking
Jul 19, 2015 01:12 AM
