Driver side Power Window keeps going down.
Old Oct 19, 2005 | 10:32 AM
FI'ed G's Avatar
hi guys, every time i close my window when it hit all they way up it starts to go down again half way open. but if i close it manually mean close it little bit at atime it close fine. Any one had this problem?
Old Oct 19, 2005 | 10:46 AM
dosa's Avatar
Yup... have it replaced by your Infiniti dealer. They'll swap the window motor for you.
Old Oct 19, 2005 | 12:55 PM
Aquinas's Avatar
yesp - I had the same thing- I'm just worried it doesn't do it again when out of warranty
Old Oct 19, 2005 | 07:31 PM
Msedanman's Avatar
O.F. Administrator
Yep, the closing tension regulator needs adjusting, or as has been said, the window motor needs replacing.
Easily fixed & warranty.
C.
Old Oct 19, 2005 | 07:36 PM
shipsaeki's Avatar
well, from what you are describing, the motor only needs to be reprogrammed. but, take it in, and they will replace the motor. if you're in a rush that day, have them reprogram and it will be ok.
G's are known for faulty window motors, happens all the time.
Old Oct 19, 2005 | 10:50 PM
betterman40's Avatar
what a trip. I thought it was just mine. I took it back and they repleaced it for me.
Old Oct 20, 2005 | 03:32 AM
nwrzG35's Avatar
yup...but mine is doing it on the passanger side
Old Oct 20, 2005 | 06:31 AM
Oxanar's Avatar
Yeah take your G in. Both of my windows went out in the same fashion. Two seperate trips. The second one it started raining. I was NOT a happy camper. But you know, folks warned me about buying a first edition.
Old Oct 20, 2005 | 12:50 PM
Gee Im Fast's Avatar
Your car is suffering from heat exhaustion...so its rolling its own windows down!
Old Oct 20, 2005 | 01:37 PM
EZZ's Avatar
EZZ
Or you smell reeeaaaal bad and its giving you a hint
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
