Arrrgh! This is finally happening to my g! Help?
Old Oct 31, 2005 | 10:22 PM
sdkingka's Avatar
It has been couple months since I got Tein H springs for g35c, (with stock shocks) and I just found out that the rear tires are wearing inside!!! The Tein H springs do not lower the car much, ( .7" front, .5" rear" ) and I thought I could get away with this issues because of that, but I guess I was wrong... I am planning to get the Tokico shocks soon, but will that solve the problem????
Old Oct 31, 2005 | 10:46 PM
Keith N's Avatar
Did you get a wheel alignment three to four weeks after your install? Were the specs within factory specs?
Old Oct 31, 2005 | 10:49 PM
PieroG35's Avatar
I think that the rear tires wear on the inside w/ the stock springs as well. The camber is aggressive from the factory. I have an 04.5' and it seems that there is a little more wear on the inside. I have 6k mi.
If your at or within camber specs don't worry about it.
Old Oct 31, 2005 | 11:12 PM
sngpimpin's Avatar
yah u need alignment and no the shocks will not solve the prob. you need a camber kit or toe.
Old Oct 31, 2005 | 11:21 PM
Poptarts's Avatar
Swerving and Weaving
camber correction kit
Old Oct 31, 2005 | 11:25 PM
Aznteazer's Avatar
Originally Posted by Poptarts
tein camber correction kit bro
i was lookin at suspension parts today and didnt come up on any Tein camber kits? got a link?
Sdkingka start a group buy for front camber, rear camber and toe arms! i'll be first one on the list!
Old Nov 1, 2005 | 10:24 AM
C-Keith's Avatar
Wheel Alignment!!! (I hope you didn't go a couple a months without one after lowering it)
Old Nov 1, 2005 | 10:36 AM
sdkingka's Avatar
yes i did, (after 2 weeks when they were all settled) and yes they were within specs.
Old Nov 1, 2005 | 10:37 AM
htownboy's Avatar
Not much you can do about it, sorry to say... I'm ready for my 4th set of rear tires at 35K, i've done regular alingments, and I rarely ever burn out, I try hard not too. I can say the Bridgestones I have on now have been the best by far... The ride is good, traction good, and they have been good in the rain also.
About $200 each at NTB
Old Nov 1, 2005 | 10:43 AM
sdkingka's Avatar
ive never seen tein camber kits! anyone got a link? and how much is it going to cost me this time to get everything done right? arg.... i love my g but this car keeps giving me challenges... modding is just becoming a expensive addiction. (someone suggested me that i put back the stock springs... hmm.. i thought about it, and i dont think i want to do that now...)
Old Nov 1, 2005 | 12:19 PM
eldy's Avatar
sdkingka,
this is the wear on my stock tires after approximately 7,500 miles on the stock suspension.
Old Nov 1, 2005 | 01:01 PM
neffster's Avatar
Follow these steps:
1. Go immediately out and get an alignment.
2. Go out and buy these for the rear. They will get your rear end camber and toe 100% back to stock specs.
3. If your front is -1.7 camber or less, buy the cusco front a-arms for ~$400 (BTW, these arms are big time backordered and you'll have to really call around to find someone with a set in stock). This will get you JUST INSIDE of stock specs (-1.25 worst case and -0.7 nominal). If you want to be at nominal or you need more than 0.5 positive camber adjustment look into the kinetix or 350EVO camber arms. Be prepared to spend well over $400 for these items.
Old Nov 1, 2005 | 01:19 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Go get an alignment to make sure you're still within stock specs and if you dont have the money to buy new tires then have the shop do a side-side rotation on your rear tires... it'll atleast buy you some time until you can afford the camber kit and a new set of tires.
Old Nov 1, 2005 | 01:28 PM
sen_jen's Avatar
Meatshake Enterprise
also, the stocks are low treadwear to begin with.
Old Nov 1, 2005 | 01:59 PM
Raznips's Avatar
yeah man i just replaced my stock tires at 13k miles and the inside was worn a couple of mm further down than the outside. It sounds normal if your allignment is in spec
