Newbie Sat Radio Question
Old Jul 26, 2003 | 02:37 PM
allanf714's Avatar
My G35 Coupe is not pre-wired but does have the Sat button. I am not clear on what exactly I need to get sat radio installed. Where do I get the necessary harness and does the harness need to be installed at the dealer or will the local stereo shop do OK. I understand that the hardware install is pretty easy once the harness is in.
Thanks in advance,
Allan
Old Jul 26, 2003 | 02:57 PM
wreck's Avatar
Running for his life!!
Re: Newbie Sat Radio Question
You will need to buy a harness. You can get it at http://www.infinitiwholesaleparts.com/en_US/ Enter JULYPARTS as the discount code when you checkout with you order and receive an extra 5% off that part.
The dealer will not install the harness from you, so you will either have to do it yourself or have a local shop do it for you.
G35C 6MT / AMG E55
Old Jul 27, 2003 | 05:13 PM
G35MD's Avatar
Pull apart your trunk to check for the harness. Take out the spare, than the black plastic covering to the left of the spare which is held by one 10mm nut/bolt. You should see the housing for your stereo amp (mine is the bose) and to the left of that is a wire bundle. If you have a white plug which is about 1.2"x0.3" secured in the middle of that wire bundle, then you have then harness. If your VIN is not too far below the published VIN cutoff for the harness, then it is prewired.
More info here
Dr. Jim
2003 DesertPlatinum G35C 6MT/Aero/Prem/Nav/HyperGround/XMSat/BSM/Tint/ClearBra/CG
2001 Acura MDX/Touring/Nav
1997 Mercedes Benx E320/Eibach Springs+Dampers/OZ Racing Superleggera Wheels
Hawk196
Sep 22, 2015 02:51 PM
Frostbite91
Aug 12, 2015 05:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
kd03g99
Jul 30, 2015 11:24 AM
