Problem parking
Old Nov 18, 2005 | 10:41 PM
punkstertommy's Avatar
Problem parking
Alright I have a later model '03 6MT. My problem is whenever I park on hill, my car always seems to roll with the e-brake up. I'm just curious is anyone in here have that kind of problem. I have to really pull that e-brake just to make it stop. The other question is if you were parking uphill to you guys put it into first gear? Thanks
Old Nov 18, 2005 | 10:51 PM
SinG35c's Avatar
Try putting it on 2nd.
Old Nov 18, 2005 | 11:41 PM
Andy2434's Avatar
Your parking brake maybe out of adjustment? I always park my cars in 1st gear with the parking brake pulled up regardless of the grade.
Old Nov 19, 2005 | 12:01 AM
g35doc's Avatar
Stupid question but you put it into first gear AFTER turning off the car and then pulling up the e-brake, right?
Old Nov 19, 2005 | 12:18 AM
oOmikeyboy's Avatar
Florida G35 Club, Premier Member
dont quote me on this but i dont think it matters. I like to pull up the e-brake first, then put it in 1st, so the car doesnt rest on the transmission. Id rather have the e-brake holding the car, and the 1st gear as a backup safety.
as for doing it with the car on or off, im not sure, i do it with it on before i get out.
Old Nov 19, 2005 | 06:08 AM
Ya I turn off the car then pull the e-brake but my car seems to want to roll downhill. It really doesn't matter if its on or off. I dunno maybe I need to take it into the dealer to check the e-brake. I got this car used so I dunno the history behind this car.
Old Nov 19, 2005 | 07:55 AM
FAST1's Avatar
Your e-brake needs adjusting or you may need new brake pads. I also leave the car in gear when parking, but it's a fail safe. You certainly shouldn't have to rely on your tranny to keep your car from rolling down a hill.
Old Nov 19, 2005 | 08:02 AM
RBull's Avatar
Rated M
It's simple. Get the e brake adjusted. There is a drum type brake mechanism that works as the e brake. The cable can be adjusted or the shoes/drum cleaned.
Always park the car in gear- either first or reverse. I always park the car in the gear that I'm going to be heading when I leave.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
