Rear Toe Arms Vs. Toe Bolt?
Old Nov 27, 2005 | 03:12 PM
Disco_Monkey's Avatar
I have been shopping for camber kits for a LONG time now and I have read countless threads.
Can someone tell me if I need the Toe Arms? Won't that eliminate the rear spring holder cup?
I have Eibach Prokits with Tokico D-specs. I'm in on a group buy for Stillen Sways. I am going to get the Stillen rear strut brace.
I want my tires to wear as evenly as possible and have my alignment to factory specs. I have an 05 6MT. 19" rims... 9.5 w/ 245 tires, 10.5 w/275 tires (S0-3's). So should I just get the Stillen rear Camber Arms and Front A-Arms or CAN the Rear Toe Arms be used with my set-up? What good will a toe-bolt do?
Thanks.
Old Nov 27, 2005 | 05:09 PM
skylar's Avatar
i suggest getting the SPC rear camber arms and toe bolts. thats what i installed on my g. it got my rear camber and toe back into specs. the kit runs for $220. the stillen rear camber and toe arms are going to cost you $850+. so you can save yourself $600 if you go with the SPC kit.
your correct about the stillen toe arms. with those you have to remove your rear spring cup. you cant use your drop springs with the stillen toe arms.
the spc kit comes with the camber arm, which is a simple swap with the stock ones. as far as the toe bolts, you have to elongate the existing toe holes to allow more adjustment... i just used a dremel for that. then you just install the spc toe bolts. from there take it to your local alignment shop for alignment.
Old Nov 27, 2005 | 06:06 PM
Thanks.
EPG35
Aug 16, 2015 04:52 PM
TreeFiddy
Aug 10, 2015 06:50 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
