What psi for winter tires?
Old Nov 28, 2005 | 03:01 AM
y.dan's Avatar
I have Toyo Garit HT 215/55/17, 225/55/17 (thanks Blitz_G35)..
how much air should I put in them?
Old Nov 28, 2005 | 03:05 AM
jonnylaw's Avatar
I'm guessing 35-37 psi.
Old Nov 28, 2005 | 07:29 AM
Coach's Avatar
I'm running 30psi in the same tires, same pressure as my summers (sedan).
Craig
Old Nov 28, 2005 | 02:11 PM
Msedanman's Avatar
O.F. Administrator
I would stick with the OEM pressures.
C.
Old Nov 28, 2005 | 03:29 PM
Beowulf's Avatar
32 psi
Old Nov 28, 2005 | 10:19 PM
B GrAzi's Avatar
33 to 36 psi
Old Nov 28, 2005 | 10:23 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm running the same tires.
I set at OEM (door sticker)
You do not want hi settings for winter
hi psi setting = less grip
Old Nov 29, 2005 | 04:06 AM
y.dan's Avatar
thanks..
it's starting to snow in vancouver..
need to get those tires on..
usual_suspect, inTgr8r.. how r these tires in snow?
Old Nov 29, 2005 | 07:42 AM
Coach's Avatar
thanks..
They're new this year, but had them in one dump of snow last week and some freezing rain yesterday, just rain today. I've found them just fine in snow, slush, water and ice based on this (very) limited experience. The best part is that they feel as good or better than the OEM Bridgestones on dry roads, although they ride just a little stiffer. They're very quiet for a winter tire, even on the highway.
I know you've got some advice to the contrary, but start with the OEM pressures from the door sticker if they're OEM size. The last thing you want to do is pump up a winter tire - you'll just kill the snow/ice traction and make them ride harshly. Watch the wear across the tread face - that will tell you over time if you are high or low on pressure. Enjoy.
Old Nov 29, 2005 | 09:01 AM
bltzkrg's Avatar
I set mine to 36psi when it was 50 degrees outside, as temps fall the pressure drops to like 33-35 so it should stay in a safe range.
Old Nov 29, 2005 | 09:10 AM
InTgr8r's Avatar
thanks..
I'd buy them again...
I live north of GTA & had no problems last year, including ski country.
Jussumman
Dec 22, 2015 10:23 AM
Dmill86
Sep 6, 2015 08:14 PM
migurus
Sep 5, 2015 09:39 PM
kevintandmd
Sep 3, 2015 06:41 PM
