Idle RPM
Old Nov 28, 2005 | 12:51 PM
GfortheCPE's Avatar
Idle RPM
My idle rpm is usually about 450-500.
But ive noticed a few times now my car idle will drop to 200-250 rpm and this will cause it to sputter a little here and there while idling.
Why would my idle sometimes drop so low?
No mods, manual tranny.
Old Nov 28, 2005 | 01:54 PM
Msedanman's Avatar
O.F. Administrator
Are you reading the tach properly? The first big division is 500rpm's.
C.
Old Nov 28, 2005 | 02:25 PM
Curt G's Avatar
Yeah, what Msedanman said.
Now, to answer your question about changing idle (possibly). Make sure you check after the engine is warmed up completely. Idle is set higher on a cold engine. Finally, turn off that A/C to check. The A/C will usually add something like 200 RPM when it's turned on.
Curt
Old Nov 28, 2005 | 02:47 PM
TheKnite's Avatar
Idle
My RPMs never dropped that low, but I did notice it move up and down slightly from time to time especially since I put in a drop in K&N filter. I mentioned it last week at the dealer when I was dropping the car off for an oil change, and they changed my throttle body. Tell your dealer next time you get your car serviced. I noticed the engine is smoother now, but not sure if it's from the new oil or thottle body, but I like it. I didn't really pay attention to the RPMs yet, but I think it improved.
Old Nov 28, 2005 | 06:42 PM
GfortheCPE's Avatar
yeh im reading the tack right
it has a small divisions every 200 rpms not 500 and each big division is 1k (5 small divisions)
its happens only seldom so no big deal..just curious if anyone else noticed a similiar thing.
What tac has 500 rpm divisions???
Old Nov 28, 2005 | 10:35 PM
cloud's Avatar
stock G running at 600rpm w/o a/c and 800 w a/c
Old Nov 28, 2005 | 10:46 PM
eddwin's Avatar
i notice the 05's and newer have different tachs, but the 04 tachs don't have markers below 500 RPM
Old Nov 28, 2005 | 11:09 PM
Rutra's Avatar
He means the very first notch is 0 and the one right after it is 500 rpm, not 100. So start at 500 and begin counting up by 100 rpm.
Old Nov 28, 2005 | 11:41 PM
imalazeeass's Avatar
my car idles i guess 600? It's the 3rd line. If 0 counts as 1 and teh very first solid bar counts as 500, then mine idles at the line right above the first line. It sometimes drops down to the first line and sputters like crap. It's kind of annoying when it gets that low, but i cant do anything about it except turn up the AC.
Old Nov 28, 2005 | 11:56 PM
Andy2434's Avatar
My '05 coupe has 4 lines between 0k and 1k. My idle is dead on the 3rd line. Soooo, I think it would be safe to say that my G idles at 600 rpm.
Old Nov 28, 2005 | 11:59 PM
Jp1's Avatar
Jp1
Gordon Gee's grounding gear might help! Plus modz are fun!
Old Jan 12, 2006 | 12:08 AM
Wanchu83's Avatar
ok
i have this problem... Would the grounding gear really help bringing my RPM up?
Old Jan 12, 2006 | 01:27 AM
arjunz's Avatar
mine drops to about 200-250 as well.... i thought it was normal
Old Jan 12, 2006 | 02:34 AM
haze's Avatar
i think the grounding gear will DROP the idle RPM, as least that is what it is advertized to do.
Old Feb 8, 2007 | 06:35 PM
Fiveseven's Avatar
i have this problem too... im getting my TB cleaned tommorow
