Questions!HELP..car got shut down!
im sorry if its has been announced before...
i was bored and went to a BIG parking lot with coupe friend drove celicas
we were doing some lanuchs,and short tracking.
ok here my thingy...
i wet my tires and "brake + gas" about 2-3k and slammed (kept in MM mode first gear bouncing ) and did a sharp turn,and rear slip then i slammed on the brake. my car did a 180 turn and stoped . then the brake got HARD!.i cant even press it down. ALL LIGHTS WENT ON and the car got shut down!. i try tap some gas..nothing happen ... turn off my car and try to start it up again...it wont start. did i **** up my car?..then waited about 2-3mins i turn the key again..it was alive again.but SLIP light keep on until i restart my car 2nd time after about 10mins ..and YES WE PLAY IT SAFE!
can any of u plz give me some adivce wat happen?why did my car got shut down? wat have i done wrong?? thank u so much.
Why in the world are you abusing your baby like that!? JK...
I've never heard anything about our cars just up and shutting off and not cranking up again??
Anybody got any ideas for Cutie wolf.
You must be a girl right? I sure hope so with that name, LOL
Yeh, take it easy on the ride bro.
I think the car went into 'limp mode' after horsing around. It needed to cool off and then be restarted to be ok.
If there are still some lights on, try an ECU reset.
C.
C.
LOL David....... u gave ur whip a minor heart attack/stroke...
You need to get out more for some cardio work like maybe makin a meet or two......
Was this here or in Mich..
chilibowl.... why don't you PM Cutie for that 411.
Q:can any of u plz give me some adivce wat happen?
A:"i wet my tires and "brake + gas" about 2-3k and slammed (kept in MM mode first gear bouncing ) and did a sharp turn,and rear slip then i slammed on the brake. my car did a 180 turn and stoped . then the brake got HARD!.i cant even press it down. ALL LIGHTS WENT ON and the car got shut down!. i try tap some gas..nothing happen ... turn off my car and try to start it up again...it wont start."
Q:why did my car got shut down?
A:"i wet my tires and "brake + gas" about 2-3k and slammed (kept in MM mode first gear bouncing ) and did a sharp turn,and rear slip then i slammed on the brake. my car did a 180 turn and stoped . then the brake got HARD!.i cant even press it down. ALL LIGHTS WENT ON and the car got shut down!."
Q:wat have i done wrong??
A:i wet my tires and "brake + gas" about 2-3k and slammed (kept in MM mode first gear bouncing ) and did a sharp turn,and rear slip then i slammed on the brake. my car did a 180 turn and stoped."
to make it short: you were hard on the car and it doesn't like it
errr. any body know wat really happen,why did the car got shutted down after rear spined and done a 180 turn?
ohh NO! im back from michigan! (never going bak again)..i do need more classes of MEETINGs...
actucally, english is my 2nd sorry about the poor grammer...-_-"
wow.. why would you attempt to do something like that in an automatic transmission veichle?.. you don't have as much control as you would with a manual. I don't know how you can stall out also with an automatic.
You probably abused the car way too much... G35 is a sports car but it's also a luxury car atleast to my point of mind.. It has many sensors and you probably messed one of them up.. such as "slip" light while you are doing 180 degree spins. You could've also damaged something mechanical for this to happen.. I would take it to the dealer and have it checked out.. if not an auto shop your familiar with.
I use to do this in my Celica all the time and it was fine.. infact I beat on the car almost everyday and brung it out into open lots every weekend.. ofcourse this is just a celica.. I wouldn't take my G out to do this..
I dunno why everybody keeps talking about you being "too hard" on the car..its supposed to be a sporty car, you should be able to throw it around a bit. I've certainly done 10x more harsh driving in my corvette.
Anyway, some cars have a fuel cutoff sensor....they are there to cut the fuel pump incase it thinks your car flipped over or crashed....maybe you somehow set that off and it takes a few minutes to reset?
