Problems with AIR......
Old Aug 8, 2003 | 04:42 PM
G_FUNK's Avatar
Is there a way to turn the fans on while the air is being recycled without the AC on. Whenever I try to turn the fans on without AC it automatically brings in outside air. Then I push the recycle button, then it automatically turns the AC on. When I drove the Sedan (loaner car), it was possible to turn the fans on while the air was being recycled without the AC on. Sound confusing? Maybe there is something wrong with the system.
Old Aug 8, 2003 | 05:21 PM
Cali_Eddie's Avatar
Re: Problems with AIR......
Yup there should be two arrows pointing up and down.. Just put it on regular and you can move the arrow's as high or as low as you want.... Should be on the left side of the console...
2003.5 White Pearl G35 Sports Coupe
Old Aug 8, 2003 | 05:54 PM
6MT_Coupe's Avatar
Hi Eddie,
I have done that before, but I think that the air is not being filtered when the AC is not on. The smell of the air is different without the AC on, and it doesn't smell good at all. Does anyone else have this same issue?
Jaime
Here's to alcohol : The cause of ... and answer to all of life's problems.
- Homer Simpson
Old Aug 8, 2003 | 06:44 PM
RamboRami's Avatar
G35driver.com Moderator
yeah, i cursed out my car when it did that to me... i guess they dont want you to turn on recirculated air without AC compressor...could be a precaution because of the activated charcoal air filter.....who knows.
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 8, 2003 | 06:45 PM
ReDRoK8's Avatar
Your AC control module might be acting up. There is a known issue with these from infiniti. You should be able to recirculate air when using fans only. I would take it to the dealership. Just my thoughts though... Peace. [img]/w3timages/icons/cool.gif[/img]
-Jason
Laser Red '03 6MT
Old Aug 8, 2003 | 07:09 PM
G_FUNK's Avatar
Rambo,
Thanks for the info. It seems as if you have the same problems. Do you think it is a defect?
"Gz_Up"
Old Aug 12, 2003 | 04:52 PM
masetodd's Avatar
"There is a known issue with these from infiniti. You should be able to recirculate air when using fans only"
Is this proven? I too cannot use Recirculate without the AC.
G35 6MT/DG/Fully Loaded
Old Aug 12, 2003 | 05:47 PM
volkracing's Avatar
Neither can I...Just haven't had time to take it into the dealer yet...
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
