Clutch Pedal Clicks
Old Mar 10, 2006 | 03:41 PM
bythabay's Avatar
well I just set up another appointment (at Niello in concord this time). Debbie is the one who will set up the appointment. She said they've done several of these and simply by looking at my records from the other dealerships she matched the problem as identical and sufficient to replace the entire clutch pedal assembly (which apparently is the only way to resolve the clicking issue).
So they have a new assembly on order for me, I can't wait to get rid of this stupid clicking! Too bad this is a nationwide problem and the pedal assembly is on national back order...
who knows why the other dealerships are trying to bursh this issue off as "normal"...
Old Mar 13, 2006 | 07:21 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Same problem here. 3 visits, no resolution. They claim to have replaced the clutch assembly but it looks the same to me. This is at coconut creek infiniti.
Old Mar 14, 2006 | 12:51 AM
bythabay's Avatar
That scares me.. i'll be placing some identifying marks on my assembly to see if it actually gets changed out.. thanks for the tip
Old Mar 14, 2006 | 01:30 PM
mellowkyle's Avatar
My clutch pedal clicks as well - they told me my clutch was getting harder to press and that it would probably need to be replaced soon, and it related to the clicking sound
Old Mar 14, 2006 | 01:32 PM
bythabay's Avatar
do I smell a TSB coming on?
Old Mar 14, 2006 | 01:35 PM
mellowkyle's Avatar
hopefully.
Old Mar 14, 2006 | 02:09 PM
mellowkyle's Avatar
the good thing is I don't believe the clicking effects driveability - it's just really annoying
Old Mar 14, 2006 | 03:39 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Extrememly annoying. Who has had success with fixing this and how?
Old Mar 14, 2006 | 08:39 PM
rgolden90's Avatar
Originally Posted by xxjkimxx
hey guys.. i just realized it today that whenever i fully depress the clutch and release it, it makes clicking noise all the time... i think that noise is from the clutch pedal... cuz even if i put my foot on the clutch lightly and then release it, it clicks from the pedal.... is it normal or should i take it to dealer to get fix?? i've done the search but nobody mentioned about this clicking noise..... am i the only one w/ this problem???
Hey xxjkimxx, My '05 g35 has the same issue. It occurs 20-30% of the time while I'm driving. It has 12k miles on it.
I live in Burke,VA so I'll be taking my car to Passport Infiniti in Alexandria. I will call Passport tomorrow and make an appointment on Thursday.
I notice you live in Springfield so you live near by to me. If you contact Passport as well, maybe they will take the hint that it is a known issue which needs to be addressed.
Old Mar 14, 2006 | 09:06 PM
RBull's Avatar
Rated M
I had success after the return visit when the parts arrived. As mentioned in my PM Parts # and description listed on invoice are:
01521-00011 pin
30631-CD014 &Rod Assy-push (I don't know exactly what this item is)
G/L all.
Old Mar 15, 2006 | 01:59 AM
accordfreak's Avatar
how loud is this clicking? and when does the clicking occur? at the top? or depressed all the way?
Old Mar 15, 2006 | 06:28 PM
rgolden90's Avatar
Yesterday I turned down my music and closed my windows. It is really 80% of the time I hear the clicking noise and not 20-30% of the time.
Old Mar 15, 2006 | 06:32 PM
rgolden90's Avatar
You can definately hear the clicking when you turn off your radio and have the windows up. The clicking occurs when the clutch pedal is fully depressed all the way.
Like I mentioned in my earlier post, I have an appointment with a dealership tomorrow and hope they repair this problem and not give me a hard time.
Old Mar 19, 2006 | 12:30 PM
rgolden90's Avatar
Passport Infiniti said that it is normal. The mechanic explained that a connector attached to the clutch assembly has a clicker. It is designed to click whenever the clutch is depressed all the way. The connector's is there so it ensures that the clutch is depressed all the way and starts the engine.
He removed the connector and showed me it. He pressed down on the clicker and it was the same noise.
Old Mar 19, 2006 | 01:19 PM
  #30
BocaCoupe's Avatar
G's Up, Ho's Down
Mine happens when releasing, and it 1/2 the way up (not touching any switches).
