Spinning Tires?
Old Jan 18, 2006 | 06:57 PM
Brando's Avatar
Originally Posted by MechEE
So with VDC off, all is well for you?
Oh yeah.....
If ....you consider smoke and sideways....as all well
Old Jan 18, 2006 | 11:26 PM
MechEE's Avatar
Originally Posted by Brando
Oh yeah.....
My last car was a VW GTI VR6 at 15 psi... about 350 ft-lbs of torque through front wheel drive... granted I swapped a Quaife torque biasing differential in so it would light up both... but that baby had some torque steer as it ripped the wheels loose! No VDC there...
Old Jan 19, 2006 | 12:03 AM
jaslui119's Avatar
Its weird that i had more wheel spin (1st to 2nd gear) when my G had 2000mi... but now with 5000mi i am having less wheel spin... In fact, my tires dont even screech anymore...i can feel the tires spinning but not enough to make it squeak.. is it because of the clutch? or other reasons....
Old Jan 19, 2006 | 12:11 AM
MechEE's Avatar
Interesting... maybe it's tire wear related?
BTW, I'm in Palo Alto as well!
Old Jan 19, 2006 | 12:23 AM
99atlantic's Avatar
E=mC^2 proves that boosting @ 15psi would add no torque over base power
ehhehehehe
Old Jan 19, 2006 | 12:34 AM
MechEE's Avatar
ehhehehehe
Now that sounds like an argument you'd stand behind!
Old Jan 19, 2006 | 12:52 AM
jaslui119's Avatar
Oh cool!..we should meet up for a drive Mechee..
my tires are pretty new.... i dunno..i am just trippin about it.. i have a feeling my clutch is worn out..
Old Jan 19, 2006 | 05:57 AM
MechEE's Avatar
I can increase your timing a few degrees if you'd like... I'm thinking of getting the car dyno'd in the next few weeks, and changing the timing between runs to see what sort of difference it makes.
Old Jan 19, 2006 | 07:23 AM
g'dup13's Avatar
Wow.....my 03 spins them all the way thru 3rd........
my 04 as well spins all the way to 3rd gear... no supercharger here.. but with vdc turned off...
Danielek
May 1, 2022 01:28 PM
magnetism80
Feb 1, 2019 10:00 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
socaldavid
Sep 5, 2015 04:35 AM
