Anybody else have this problem?
When I'm in Manumatic Mode in my Coupe and I'm really pushing it in the 6300 - 6800 range in first gear and go to shift to second I get this very Jerky sorda feel. It shifts pretty quickly and the RPM's go down but it's like it takes a second and then it's almost like the Tires finally grabe the pavement and I start going. I don't know if I'm explaining it right but basically when I go from First to Second gear in MM mode I get this really Jerky head goes against the head rest feel. I don't notice it as much in other gears except 2 to 3 it's kinda there but not as pronouned. The weird thing is I've pushed my car before and never had such a jerky feeling and it has only done this recently unless I'm crazy. I haven't done any more mods so I don't know. Does this happen to others in MM mode? Am I'm ****ing wrong or not taking my foot off the gas enough? Thanks in Advance
Its normal. Don't take your foot off the gas when you shift. It makes the feeling more pronounced. The reason it is doing it is that the ECU is adapting to your normal style of driving. If you pushed the car around a lot, then it would change how it shifts. 1-2 and 2-3 can be rough but shouldn't be a problem.
my shift from 2-3 feel as if the tranny is about to rip apart... its almost like a THUD sound and the car jerks. Yet all other gears are fine.
This happens at any RPM range. With all other gears all RPM range no issue.
I have no clue why 2-3 shifts are soo brutal
itgogitrev
Sep 23, 2015 07:08 PM
