How to do a burn out?
Old Jan 28, 2006 | 01:10 PM
kenchan's Avatar
the only time i do burn outs is when the tires are brand new and need to
remove the release lube. some tires take forever for that release lube to
wear out.
otherwise, i rarely do burnouts. just not suited for my clean, fast
driving style.
Old Jan 28, 2006 | 02:02 PM
Sukairain's Avatar
I just hold the "A" button at launch and the car automaticly does a nice burn out. That's on the XBox, you might have to hold a different button on the G35, but I am not sure.
Old Jan 28, 2006 | 04:01 PM
IlirG's Avatar
Its fun once in a while. Automatic is easy, hold down the break hard, pres down the gas, its been getting easier with each mod I do. But deffenitely, drifting, and over steer is much much more fun than burn outs.
Old Jan 28, 2006 | 04:13 PM
thx007's Avatar
Originally Posted by b1kg35
are u serious? rain needed to do a burnout in a G?
obviously no one has told you that when u press both the brake and gas pedal at the same time. the ecu cuts the power. to get around this, you have to pull the brake fuse. someone also sells a switch, so you don't have to pull the fuse everytime a burnout is wanted...
This was for a beginner at burnouts. He obviously was having problems and putting unwanted stress on the drivetrain. All I was saying is that to learn, he may be better off practicing on a slick surface, ie; Rain.
As for the ECU pulling power, this may be true, but it doesn't keep my 5AT G from sitting and burning them down if I want (which I also don't do often, but perhaps 2-3 times). I've never had to pull any fuses...
Old Jan 28, 2006 | 05:26 PM
WaLLy's Avatar
LMAO
Old Jan 29, 2006 | 12:15 PM
mal_TX's Avatar
VDC OFF via the switch in the cabin will only turn VDC off when you are NOT on the brake pedal. If you are pressing the brakes, VDC is on as part of the ABS system. This makes it hard to do "brake stands" or "burn outs" Basically you shouldn't do it because the car is actively trying to stop it from happening and you might damage parts of your car.
If you want VDC off for "on the brake" time you're going to have to pull a fuse or a wire or something
Old Jan 29, 2006 | 12:44 PM
04txg35coupe's Avatar
If you have a manual and want to do a burnout, you can heel-toe it. But that is pretty hard. You' ve got to have experience to do it properly.
Old Jan 29, 2006 | 07:44 PM
Reddragon's Avatar
Thank u guys, but I think b1kg35 is right. By the way I have a 6mt G. Gonna try to find a switch for this ECU crap.
Old Jan 29, 2006 | 08:20 PM
Jtrain's Avatar
Really? Its right trigger for me
ANyone else PISSED OFF theres no G35 in NFS most wanted?
Neither am i.
But having Benz' and M3's is funny-- seeing em all riced out
Old Jan 29, 2006 | 09:57 PM
MyGUnit's Avatar
pisses me off about no g35 in need for speed....
but the cop pursuits are REALLY fun
Old Jan 29, 2006 | 10:13 PM
MrBillMartin's Avatar
Originally Posted by marbels
smoke as much weed as possible
he didn't say hes trying to become a burntout hes said hes trying to do a burn out. damn weed head.
Old Jan 30, 2006 | 12:33 AM
Flavour's Avatar
you'll want a line lock, having the brakes on on the rear wheels isnt going to make for a good burnout. i don't know why you'd want to do this on a g anyways.
Old Jan 30, 2006 | 03:01 AM
cscirpoli's Avatar
???? Doing a burnout in a manual is the easiest thing in the world...Rev it up to about 5k, drop clutch let tires spin...done, hell you dont even have to do that, if you're really good.
My absolute favorite is taking my friends out for a little 0-80 mph action, chirping the tires in 2nd and 3rd gear. Man, in 2nd gear if you hit it good, those tires will do more than chirp, they'll spin up for a few secs. Fun car
Old Jan 30, 2006 | 03:26 AM
cloud's Avatar
better not try that, the G will slip the clutch when dropping the clutch above 3k if i'm not mistaken.
Old Jan 30, 2006 | 05:09 AM
  #30
Sukairain's Avatar
Neither am i.
Haha, I think Nissan didn't want their cars portraited as criminals' choice of weapon, so they wouldn't license cars for the game. Kind of funny. I am just happy the G35C is in Kaidou Battle 2, GT4 and NFSU2.
